What I am wondering is if it is possible to switch the DC pump(s) to full during the storm then reset back to normal mode. I wouldn't want this happening every day but one or twice a month would be pretty cool to swoosh stuff around. May even be better than my turkey baster
Weather Simulation for Dimming expansion module
saf1
Re: Weather Simulation for Dimming expansion module
Does the weather simulation pick a random day and time of the month to actually fire or is it every day or set in code based on us?
It should be fairly easy to add some powerhead action. Was thinking about this yesterday actually. If I get to add it, I'll post my results.
saf1
Hate to ask this, but does the weather simulation library also simulate lighting?
I added the code this morning and have been toying with it when about an hour into post loading the code lights dimmed, assuming cloud, then all of a sudden flashed several quick successions with my blue channels being mostly called. Threw me for a loop but figured I'd ask.
I'm going to assume it does but wanted to be sure in case my multi chip can't handle it or I have to edit a value somewhere that maybe I missed.
The example I was using as a reference had it called as:
Global variable:
byte PWMChannel[6];
CheckCloud();
ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
Global variable:
byte PWMChannel[6];
CheckCloud();
Yes. You can modify the lightning chance and frequency in the defines above the CheckCloud function you added
saf1
lnevo wrote:Yes. You can modify the lightning chance and frequency in the defines above the CheckCloud function you added
Thanks. That got me to the correct location and I was able to modify. Also found an error in the code that was causing the RW's to run at 100% rather than the 40 like I thought.
Thanks for the information.
troylong45
has this been done yet the full power overide for storm chance for dc pumpsaf1 wrote:Does the weather simulation pick a random day and time of the month to actually fire or is it every day or set in code based on us?
troylong45
lnevo wrote:It should be fairly easy to add some powerhead action. Was thinking about this yesterday actually. If I get to add it, I'll post my results.
lee did you guys find out to add the powerheads into the storm deal?
troylong45
Colin was looking at it
