I changed from Bellsouth DSL to Comcast Xfinity about 2 weeks ago and lost connectivity to my WiFi.
I changed the settings on the Comcast router to duplicate the old settings on my old netgear router identically so that I wouldn't have to go around to all my devices that connect to the internet like my TV's, phones, the RA the PS3 and the WII's and change the setting in them.
Everything works perfectly with the old setting on them except the RA WiFi.
I must say that I was having problems with it before changing internet companies where my IP address would change but the RA would not update to the new IP address unless I rebooted it.
I reformatted my PC for other reasons and reinstalled the Reef Angel Controller software and still the communications port light was just blinking green every 2 seconds or so.
I tried connecting with the WiFi adapter Setup Utility and it would not see the module.
I set the serial port to com 3.
No connectivity to it and the communications light will just blink green every 2 seconds or so.
The Bluetooth connectivity thru the WiFi module still works fine though.
Connected to serial port COM3
Any suggestions or is it dead
Thank for the help.
