Max and Min Temp
jsclownfish
Max and Min Temp
Post by jsclownfish »
I am thinking about reducing my custom main screen footprint by removing the graph function. What I really want to know is did the temp go over or under a 'safe' temp. So I thought I could just show the max and min temp in the last 24 hr. period. I usually check the screen once a day or so anyway. Will this code work or is there a better way to do it?
Jon
long previousMillis = 0;        // will store last time was updated
long interval = 86400000;       // interval for 24hrs
int maxtemp = 0;
int mintemp = 0;
int currentTemp = 0;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TK:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_BLACK, 23, 13, 10);
// Display the Room temperature
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,5,23,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxTemp, 0, 23, 23, 10);
// Display the Sump temperature
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,5,33,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 33, 1);
ReefAngel.LCD.DrawOutletBox(12, 45, TempRelay);
unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval && ReefAngel.Params.Temp1 > currentTemp)
      maxTemp = ReefAngel.Params.Temp1
      // displays max temp in last 24 hrs.
      previousMillis = currentMillis;
      // resets 24 hr clock
  if(currentMillis - previousMillis > interval && ReefAngel.Params.Temp1 < currentTemp)
      minTemp = ReefAngel.Params.Temp1
      // displays min temp in last 24 hrs.
Re: Max and Min Temp
no :(
Try this:
int maxTemp = 0;
int minTemp = 0;
if (now()%86400==0)
  maxTemp=0;
  minTemp=0;
if (ReefAngel.Params.T1>maxTemp) maxTemp=ReefAngel.Params.T1;
if (ReefAngel.Params.T1<minTemp) minTemp=ReefAngel.Params.T1;
jsclownfish
Thanks, this seems much simpler. How does this work?
if (now()%86400==0)
  maxTemp=0;
  minTemp=0;
I'm looking for the peak max and peak min in a 24 hour period, so I don't see how it tracks the current high and low for comparison.
Thanks again,
Jon
This code resets the data each day. There are 86400 seconds per day. After that amount of time has elapsed, it will reset the max & min temps.
if (now()%86400==0)
I fixed the code otherwise you would have a problem and it would never be set. If you set the min value to 0, then the temp of the T1 will never go below 0. So we just set it to what the current temperature is of the tank and have it update appropriately. While we are at it, might as well set the max temp to the same value so it will have a decent starting point.
Then, the next set of code compares to see if the T1 temp exceeds the max temp or is less than the min temp. Then updates the min and max values appropriately.
Good catch :)
jsclownfish
OK I think I am following this. However, if it only resets once a day (say midnight) then if I look at it in the morning won't it only be the peak max and min of the last ~8 hrs vs. the last 24 hrs?
Jon
jsclownfish
I suppose I could also print the time the peak was hit on the screen, that might help. :)
jsclownfish
I tried this code and the display seems to respond correctly for the max temp going higher, but the low stays at 0. Not sure what's going on.
-Jon
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
//Actinic and Daylight PMW are on the LED moonlights
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
int maxTemp=ReefAngel.Params.Temp1;
int minTemp=ReefAngel.Params.Temp1;
byte wmport=Port5;
boolean wmdelay=false;
byte wmpulse=0;
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "jsclownfish";
prog_char probe1_label[] PROGMEM = "Tank";
prog_char probe3_label[] PROGMEM = "Sump";
prog_char relay1_label[] PROGMEM = "Heater1";
prog_char relay2_label[] PROGMEM = "Heater2";
prog_char relay3_label[] PROGMEM = "MHalide";
prog_char relay4_label[] PROGMEM = "Actinic";
prog_char relay5_label[] PROGMEM = "WM1";
prog_char relay6_label[] PROGMEM = "WM2";
prog_char relay7_label[] PROGMEM = "Main";
prog_char relay8_label[] PROGMEM = "Fan";
if (now()%86400==0)
if (ReefAngel.Params.Temp1<minTemp) minTemp=ReefAngel.Params.Temp1;
if (ReefAngel.Params.Temp1>maxTemp) maxTemp=ReefAngel.Params.Temp1;
ReefAngel.LCD.DrawGraph(1, 75);
  ReefAngel.Init();  //Initialize controller and start web banner timer
  ReefAngel.Timer[4].SetInterval(180);  // set interval to 180 seconds
  ReefAngel.Timer[4].Start();
  ReefAngel.FeedingModePorts = B00110000;
  ReefAngel.WaterChangePorts = B10110000;
//  ReefAngel.OverheatShutoffPorts = B00000111;
//  ReefAngel.LightsOnPorts = B00001100;
  ReefAngel.Relay.On(Port5);
  ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port7);
  // Specific functions
  //1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
  ReefAngel.StandardHeater(Port1,788,792);
  ReefAngel.StandardHeater(Port2,770,792);
  ReefAngel.MHLights(Port3,10,0,20,0,5);
  ReefAngel.StandardLights(Port4,9,0,21,0);
  ReefAngel.StandardFan(Port8,792,820);
  // Wavemaker Code with night option
  if (ReefAngel.Timer[1].IsTriggered() )
    if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
    {  //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
       // byte endPWM, byte Duration, byte oldValue)
      wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(wmpulse);  // WM delay function from 30-170 sec.
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        if (wmport==Port5) wmport=Port6; else wmport=Port5;
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(200-wmpulse);  // WM bursts timing from 170-30 sec.
        ReefAngel.Relay.On(wmport);
        wmdelay=true;
      //8a-10p normal wave settings
  //Using Daylight ATO high signal piezo buzzer when temp exceeds 83F
  //other options are lowATOpin or the LED pins as ReefAngel.PWM.SetDaylight(100); else ReefAngel.PWM.SetDaylight(0);
if (ReefAngel.Params.Temp1>830)
  pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,HIGH);
  {pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,LOW);
    //Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
   ActinicPWMValue=PWMSlope(7,00,22,0,0,100,60,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(7,00,22,0,0,100,60,DaylightPWMValue);
// Web Banner stuff
        ReefAngel.WebBanner();
These lines:
Will always return 0. The reason is that the values are not initialized yet. What you should do is change them to this:
int maxTemp=0;
int minTemp=2000;
I'm setting the maxTemp to 0 and the minTemp to 200.0. The reason it is this way is so that the T1 value will ALWAYS be less than 200 (unless you are boiling your fish) and your min value will be updated with the T1 value. And T1 value will always be greater than 0.
The next suggestion I have is to move the temp check code to be the very first few lines of your DrawCustomMain function to force the values to be set before they are displayed, otherwise you will see 0 and 200 on your screen temporarily.
// update the min and max temps
if (now()%86400==0)
jsclownfish
Thanks! That fixed it. :) I also tried to add a time stamp (borrowing from your code) to show when the peak was hit high and low. Looks pretty good, although I seem to get an extra 0 on the max time stamp after the "PM", but not on the min time stamp? I like this idea alot and I think I'll try the same for the pH.
Am I correct in that this resets once a day or does it check each reading to see if it has been 24 hours since the last peak reading?
-Jon
Here is my latest version with the timestamp...
int maxTemp=0;
int minTemp=2000;
byte wmport=Port5;
byte wmpulse=0;
void DrawTime(byte x, byte y)
//byte iTimeHourOffset=0;
    char text[13];
    char temp[]="  ";
    //if (iTimeHour>12) iTimeHourOffset=12;
    itoa(hourFormat12(),temp,10);
    if (temp[1]==0) strcat(text,"0");
    strcat(text,temp);
    strcat(text,":");
    itoa(minute(),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(second(),temp,10);
    strcat(text,temp);
    if (isAM())
        strcat(text," AM");
        strcat(text," PM");
    ReefAngel.LCD.DrawText(DateTextColor, DefaultBGColor, x, y, text);
if (now()%86400==0)
  DrawTime(60,33);
  DrawTime(60,23);
ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 33, 10);
      if (wmdelay)
        wmdelay=false;
        wmdelay=true;
// Web Banner stuff
jsclownfish
Hmmm. I also seem to lose the time stamp of the peak if I go to the menu for feeding or water change. Is this a problem with the order of commands? The peak values aren't lost.
Thanks for all your help!
-Jon
That's because you were just drawing the time and not storing it.
Try this:
int maxTemp=0;
int minTemp=2000;
time_t tsmax=now();
time_t tsmin=now();
byte wmport=Port5;
byte wmpulse=0;
void DrawTime(byte x, byte y, time_t ts)
    char text[13];
    char temp[]="  ";
    itoa(hourFormat12(ts),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(minute(ts),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(second(ts),temp,10);
    strcat(text,temp);
    if (isAM(ts))
        strcat(text," AM");
        strcat(text," PM");
if (now()%86400==0)
  tsmin=now();
//  DrawTime(60,33);
  tsmax=now();
//  DrawTime(60,23);
DrawTime(60,23,tsmax);
DrawTime(60,33,tsmin);
      if (wmdelay)
        wmdelay=false;
        wmdelay=true;
// Web Banner stuff
jsclownfish
I tried this code and it gives me a flashing screen with a garbled time flashing but nothing else.
I've seen that happen before when I was trying to modify the custom main. Not sure what causes it.
-Jon
Ah, you missed one line on your DrawDate() function.
    strcpy(text,"");
That line is very important as it initializes the variable with nothing. Otherwise, you get remaining garbage and it messes up when you concatenate strings with strcat()
So, here is the code with that line added:
int maxTemp=0;
int minTemp=2000;
time_t tsmax=now();
time_t tsmin=now();
byte wmport=Port5;
byte wmpulse=0;
    char text[13];
    char temp[]="  ";
    strcpy(text,"");
    strcat(text,temp);
    strcat(text,":");
    strcat(text,temp);
    strcat(text,":");
    strcat(text,temp);
    if (isAM(ts))
        strcat(text," AM");
        strcat(text," PM");
if (now()%86400==0)
  tsmin=now();
//  DrawTime(60,33);
  tsmax=now();
//  DrawTime(60,23);
      if (wmdelay)
        wmdelay=false;
        wmdelay=true;
// Web Banner stuff
jsclownfish
Thanks, that did the trick.
-Jon
