I added a float valve to my skimmer drain container, so that the skimmer would shut down if the container fills up. However, after adding the following code I found that it completely cancelled out my skimmer delay settings. Is it possible to have the delay and the "override"?
ReefAngel.Relay.Override(Port8,0);
ReefAngel.Relay.On(Port8);
Lost skimmer delay setting.
Re: Lost skimmer delay setting.
Take out the else. You use an override because you want to manually enable the skimmer after this type of event.
paperdesk
