Odd problem here.
I recently changed firewalls.
I added the rules to do my port forwarding to my RA - which I know are working 'cause the android app works from both internally and externally.
However, my Portal is not working. When I look at the RA Portal, the wifi IP address is wrong.
I use No-IP and I can confirm that it is updated in "internet land".
Any thoughts?
WiFi Woes
Smotz
Re: WiFi Woes
Man, this place cleared out..
I am also able to get to my water lever chart @
http://forum.reefangel.com/status/chart ... filter=WL1
But still the portal doesn't work.
Does it work for anyone or is it just me?
Kungpaoshizi
Re: WiFi Woes
I'm here
Though I don't have a unit yet, you're referring to the main login to view the RA from the internet? (portal)
Apologies, still learning..
Smotz
Re: WiFi Woes
I think I got some IP Masquerading rule issues..
- cosmith71
Re: WiFi Woes
Portal has been working fine for me.
There's a link around here somewhere that can tell you if the appropriate port is open. Lemme see if I can dig it up.
- cosmith71
Re: WiFi Woes
Use port 2000.
Can you post a screenshot of your portal screen?
Use port 2000.
Smotz
Re: WiFi Woes
My bad. All fixed. Looks like I had an IP in my user config instead of my DNS hostname. Not sure why I would do that but all fixed.
