I don't think I am getting notifications anymore?
Smotz
Can anyone else confirm ?
Re: I don't think I am getting notifications anymore?
Can you go ahead and edit every one of your triggers and save them again?
Let me know if that helps.
Smotz
rimai wrote:Can you go ahead and edit every one of your triggers and save them again?
Did it twice. Still not working. What am I doing wrong?
Are you sure your wifi attachment is working?
It says the last data sent to th portal was in 09/19
Smotz
Thats really bizarre - I see that too, now. On the portal I am able to toggle my devices - I turned my fuge light on and off..
let me try some things. You may see zeros.
I can send data just fine. It took my forced data.
There may be something misconfigured with the wifi attachment.
Try running the Tera Term macro: http://forum.reefangel.com/viewtopic.php?f=3&t=4601
Smotz
I am getting them now. Looks like a DNS thing.
I use NO-IP to resolve http://www.meanbiak.com to my dynamic IP. When I put http://www.meanbiak.com as my wifi address it automatically translates that to my current IP and doesn't keep the hostname.
in any case, thank you for your help - it looks good now. If I have any more problems I will try your suggestion.
Smotz
Scratch that - I am not getting notifications
Roberto - I got a few yesterday while you were testing but nothing since. The portal looks like it's updating...kinda..
I'll try the wifi thing you suggested but anything you can think about on your end..
It's not updating some things - for instance, it's not displaying my second expansion outlets.
Also, make sure you have the Portal function in your code.
The Portal is only updating in live mode, but it is not receiving data for some reason.
Smotz
I thinking it's the Sophos UTM9 firewall I put it. Gonna switch back to Untangle tonight and see how that goes.rimai wrote:Also, make sure you have the Portal function in your code.
Smotz
It was the firewall I put in - Sophos UTM 9 - it blocks everything! Couldn't figure out how to enable things. I put Untangle back in - all is well in the world.
Roberto - thank you for everything!
