New to code ra and controls
Re: New to code ra and controls
Yep
troylong45
Post by troylong45 »
K my Internet provider hopefully will walk me through it. It's there router lol
troylong45
yea got it Reef Angel wifi address: 98.157.208.157:2000
My reefangelid:
troylong45
Connection Status:
Ready
Last Update:
10/20/2015, 7:17:28 PM
Displaying data from:
Reef Angel Controller (live)
now i need to see what the dimming does i think it was not working right
Awesome. Start by reviewing the settings in memory and then we can re-review the code. I dont think your code is setting all your channels well. Would be good to know how your mapping your channels and ports so if you can post that at some point it will help.
You can do the following to see graphs of your pwm values:
http://forum.reefangel.com/status/chart ... lter=pwme3
troylong45
ill let it run for a day or 2 and check the gragh
troylong45
if i set the time for lights on and off for internal memory that gets overridden by the sunrise code ? will the sunrise code with geological coordinates reflect in the graph for relays and dimming .and clouds and lighting reflect in the dimming graph ?
It really depends on the code. The SunLocation will set the start time and end time for StandardLights. ActinicLights is based off of that using the ActinicOffset value. We can adjust the time in the code by setting the offsets for rise and set.
These times will also affect when the StanardLights turns on the relays.
    ReefAngel.DayLights( Port2 );
The dimming is controlled by these statements
    ReefAngel.PWM.Channel0PWMParabola();
    ReefAngel.PWM.Channel1PWMParabola();
But are you only using 2 channels? I'd still like to understand the layout of your connections and how many boxes your controlling...
So the code above will set the dimming based on what youre seeing in Internal Memory, however then you do this:
    DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,30,240,0);
Which is hard-coding the pwmslope to those times and percentages. What I would do is replace that with
DaylightPWMValue=GetChannelValueRaw(1);
After that, the CheckCloud() function gets run which uses the DaylightPWMValue to figure out what to set the clouds too. It then updates the channel with the next line
ReefAngel.PWM.SetChannelRAW(1,DaylightPWMValue);
So you have quite a few things going on and mixing hard coded with set values. I think the recommendation above will help make things clearer, but not sure what you're seeing off at the moment. If the times your seeing that get updated in the InternalMemory aren't what you want then either adjust the GPS coordinates, or do this to change the offset
sun.setOffset(1,-1); // this will add an hour to the sunrise and remove an hour from sunset
Somethign to keep in mind which gets confusing. The RA has no concept of TimeZone so it thinks that it is GMT which can make it a little confusing from what the expectations might be. So like I said, let's discuss what you're actually seeing and what you want to get it to.
Ok here's a correction for the PWM graph link I put up before
http://forum.reefangel.com/status/chart ... lter=pwme1
I can see now a bit what's going on.. it does look the cloud stuff is working. The only wierdness was the channel going to 32% all night long and I believe that's because of the statement I mentioned that used hard coded settings.
Try this:
#include <SunLocation.h>
SunLocation sun;
int DaylightPWMValue=0;        // For cloud code
int Latitude=-18;
int Longitude=147;
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    sun.Init(Latitude,Longitude);
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 7
    #define Min_Clouds_per_Day 1
    #define Max_Clouds_per_Day 2
      // In this example, start cloud after noon
    #define Start_Cloud_After NumMins(12,00)
    #define End_Cloud_Before NumMins(21,00)
      // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
      // of effects or unforseen result could happen.
      // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
      // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
      // Add Random Lightning modes
    #define Calm 0    // No lightning
    #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
    #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
    #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
    #define Mega2 4   // Like Mega, but with more lightning
      // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
      // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
      byte LightningModes[] = {Mega2,Mega,Mega};
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
      static byte lightningMode=0;
      static time_t DelayCounter=millis();    // Variable for lightning timing.
      static int DelayTime=random(1000);      // Variable for lightning timimg.
    #ifdef forcecloudcalculation
      if (cloudchance==255)
    #else
    #endif
          randomSeed(millis());    // Seed the random number generator
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
          DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
          if (chooseLightning)
            chooseLightning=false;
          switch (lightningMode)
          case Calm:
            break;
          case Mega:
            // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              // Send the trigger
              Strike();
              DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
              DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
            break;
          case Mega2:
            // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
            // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
              else lightningstatus=0;
              if (lightningstatus)
                DaylightPWMValue=4095;
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          if (cloudindex < numclouds)
        /*ReefAngel.LCD.Clear(255,0,120,132,132);
         ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
          int x=0;
          else x=17;
          //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
          ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
          else x=35;
          //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
          ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
        //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
        ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
        if (lightningchance)
          int x=0;
          if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
          else x=57;
          //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
          ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
          if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
          else x=75;
          //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
            ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
    void Strike()
      int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
      for (int i=0; i<a; i++)
        // Flash on
        int newdata=4095;
        Wire.beginTransmission(0x40);      // Address of the dimming expansion module
        Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
        Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
        Wire.write(newdata>>8);            // This sends the MSB
        Wire.endTransmission();
        int randy=random(20,80);    // Random number for a delay
        if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
        delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
        // Flash off.  Return to baseline.
        newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
        Wire.beginTransmission(0x40);    // Same as above
        delay(random(30,50));                // Wait from 30 to 49 ms
        wdt_reset();    // Reset watchdog timer to avoid re-boots
      cstart*=60;
      cend*=60;
      if (n>cend) return (int) PWMStart;
    ReefAngel.Relay.DelayedOn( Port3 );
    ReefAngel.Relay.DelayedOn( Port4 );
    ReefAngel.StandardHeater( Port6 );
    ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive());
    ReefAngel.SingleATOLow( Port7 );
    ReefAngel.PWM.SetChannel(0,0); // Make sure we're at 0% at night
    ReefAngel.PWM.Channel0PWMParabola(); // Set Channel0 based on Parabola and Memory values
    ReefAngel.PWM.Channel1PWMParabola(); // Set Chanenl1 based on Parabola and Memory values
    sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
    DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
    CheckCloud(); // Apply cloud routine
    ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
    ReefAngel.Portal( "troylong45" );
    ReefAngel.DDNS( "209.18.47.61" ); // Your DDNS is troylong45-209.18.47.61.myreefangel.com
troylong45
ok ill try to load the code tomorrow after work. right now its on my moms tank for a litte while cus im breaking my main tank down to reset it due to algae . so im running 1 blue 1 white channel but i have not reran the dimming control to the marsaqua yet. so not sure what the dimming actully looks like yet.
for my main tank when its done
dimming and light relays 1 left bl ch 1 right bl ch 1 left wh ch 1 right wh ch.
troylong45
is the new code u posted updated with the things needed from above that u mentined?
Yes, but I don't understand your dimming map. everything is channel 1?
troylong45
sry no currently will have dimming expansion pwm 0 for blue channel and pwm 1 for white channel .
troylong45
look like i need time change the location im using is 10 hours ahead of gmt and 14 hours ahead of me but my time has no bearing on the gps time right so i need to of set the time by 10 hours so since it is 10 hours ahead i need look like this
sun.setOffset(10,-10); // this will add an hour to the sunrise and remove an hour from sunset
if thats right were does it go
troylong45
looks like 12 hours difference compared to internal memory . and i have location as great barrier reef and i know its normaly 12hrs of daylight but it has the daylights set to that. is that to much whites ?
I would do 12 hours for actinic and 8 for blues. Go by the recommendations on the fb group files section :) you can use the offsets to fine tune it. I flipped the latitude to the norther hemisphere so it would follow our season and then i swung the latitude over to mine, i probably should have use GMT longitude.
troylong45
since the gps location has daylights set for about 12 hrs is there a way to knock off 2 hours daylight from the sunrise and 2 hours from the sunset so i get estimated 8 hours daylights and still use the same gps
Set the actinic offset to 2 hours and it should do exactly that.
troylong45
Looks like it did thanks now I reset every thing to proper time that I want. I was looking at the moon time and the moon rise is right but not the moonset I don't think we added the moon code in . But currently no moon lights anyway so I'll wait till I get them to do that. Looks like one of the channels hasn't been going below 2% but I'll keep an eye on it I don't think it should matter though cus the relays still turn off so don't seem like should be a big deal I'll leave everything as is now and keep an eye on it and reorder parts to hook up the dimmers to the light.
You won' see it go to 0. The portal doesn't store 0s and it only gets data every 5 minutes from the controller. We didn't do anything in the code for moon that I recall if you added then let's see what you did. We can do that pretty easily. I have the same kind of time issues that the sunlocation class does in that it doesn't really account well for timezones etc. but the schedule should be roughly what real moon does. 12 hours of moonlight and if rise is 8am-8pm, next day should be 9am-9pm and continuing. I'd love to see more feedback on your findings. The Moon class is a reimplementation of some code I found so it doesn't have functionality like offsets and stuff, but we can figure out some ways if you want more control.
troylong45
The time zone to get my time right for around 8-8 sunrise and sunset I had to use gmt +2 -35 longitude or +35 I can't remember but I used -18 latertude to simulate the great barrier reef. So far look ok. In paper atleast lol since it's at my mom's never really see it. But when I break my 75 down and start clean I'll get better watch on it. I think everything is ok now till I add moonlights, hook up my dimmers and add more floats or water levels do u prefer water level or floats . Water level seems like the pvc will take a lot of room can ra be coded for certain reading of water level like use one for return chamber low and shut off return pump and as well operating the ato low and high settings?
Yes :) water level sensor is great. It's 1/2" pvc i believe doesnt take up much space. Roberto can confirm the dimension, mines out of reach in my ato reservoir.
troylong45
It says 1/2 on the website I guess it would be ok. So ur only usein one and its in the ato tank. Then u use high and/or low float for water level to activate the ato
troylong45
if i get a water level sensor can it run different things from 1 WLS the return chamber i have will be 5" water level
1 if it drops below 3" turns off return pump till cleared
2 ato turns on when water level falls below 4.75" and ato off above 5"
3 skimmer shuts off above 7" and on below 6"
seems like this all can be done with proper coding
Absolutely. Best thing about the water level sensor. Only thing to consider is that it is measure by % but you calibrate it for your use. Roberto uses it to control his return pump speed with a full siphon drain. No gate valve or backup drain needed.
I would still consider the multi sensor though cause you'll want it for other stuff. They can be used together too for 5 total channels.
troylong45
U read my mind I was thinking the multi for the ato storage and skimmer collection cup to be added later
troylong45
something is not right the relay 1 2 3 and 4 if not operating with auto light cycle 1 is left blue 2 is let white 3 is right bule 4 is right white i want a 30min delay in the light schedule for the right as well and on the dimming expansion 0 is 0 is left blue 1 is let white 2 is right blue 3 is right white and i want 30 min delay on the right dimming as well.
relay 3 is staying on and 1 2 and 4 is staying off
the only dimming that looks like is working is 1
and when i go in the app to over ride the dimming it works but everything is off buy 2 lines meaning if i override dimming 2 it overides 0 and same for 3 it overrides 1 and 4 doe 2 and 5 does 3 . but if i override 0 or 1 it updates and does nothing?
    SunLocation sun;
    int Latitude=-18;
    int Longitude=-87;
        ReefAngel.FeedingModePorts = Port8Bit;
        ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
        ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
        void CheckCloud()
        #else
        #endif
              if (cloudchance)
          if (cloudchance)
              case Calm:
                break;
              case Mega:
                  // Send the trigger
                  Strike();
                break;
              case Mega2:
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              int x=0;
              else x=17;
              else x=35;
              int x=0;
              else x=57;
              else x=75;
        void Strike()
            // Flash on
            int newdata=4095;
          cstart*=60;
          cend*=60;
        ReefAngel.ActinicLights( Port1 | Port3 );  // actinicLight power
        ReefAngel.DayLights( Port2 | Port4 ); // daylight power
        ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive()); // skimmer
        ReefAngel.StandardHeater( Port6 ); // heater
        ReefAngel.SingleATOLow( Port7 ); // auto top off
        ReefAngel.Relay.On(Port8); // return
        ReefAngel.PWM.Channel3PWMParabola();
        ReefAngel.PWM.Channel4PWMParabola();
        CheckCloud();
        ReefAngel.DDNS( "reef" ); // Your DDNS is troylong45-reef.myreefangel.com
Looking at your code, your Actinic and Daylight problems are coming from these lines:
When you use the | (bitwise OR operation), you are telling the code to take the value of Port1 and combine it with Port3. That will not give you what you are wanting. That will give an entirely different Port to be toggled on/off.
So, to get Port1 and Port3 to operate on the same schedule and to get Port2 and Port4 to operate on their schedule, you will need to do this:
ReefAngel.ActinicLights(Port1);
ReefAngel.ActinicLights(Port3);
ReefAngel.DayLights(Port2);
ReefAngel.DayLights(Port4);
You need a separate line for each of the ports and cannot combine them into the same line, otherwise it will not work.
You removed the code that Lee provided for you that was setting things correctly. You went back to hard coding your values.
This is what he gave you:
    ReefAngel.PWM.Channel1PWMParabola(); // Set Channel1 based on Parabola and Memory values
this is what you are using:
        CheckCloud();
In this code, you are only using channels 0, 1, 3, 4. You are then forcing in code the value for DaylightPWMValue by using the PWMSlopeHighRes function.
Lastly, you are overriding your PWM channel 1 with the output from the CheckCloud function.
So, I’m not exactly sure what you are trying to do with your code. Based on your code, when you use the ChannelXPWMParabola() function, that will set the PWM channel X based on the parameters stored in memory for the Parabola function. After you do that, you are calling the sun functions and then the check cloud function and only using that output on PWM Channel 1.
SUMMARY:
You have lots of things going on. Since you are having issues, it is best to go back to the basics.
  • Let’s get the relays function properly with my suggestions above (separate out the relays to their own lines).
  • Then, lets remove the sun and checkcloud function calls and let the PWMParabola do its job and set the values.
Once we know those channels are functioning properly, then we can proceed onward with using the sun and checkcloud functions and get them to be used on the proper channels. I have not used the checkcloud function so I cannot answer much based on that or tell you how it works. I probably could figure it out, but I do not have the time and others can do this much faster than me.
troylong45
Ok yea I don't know y I codes the relays in same area like that just thought maybe would work lol.
troylong45
here is a new code i just now did lll go from this
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.Relay.On( Port7 ); // Return Pump
    ReefAngel.ActinicLights( Port1 ); // Left Actinic Light power
    ReefAngel.DayLights( Port2 ); // Left Day Light power
    ReefAngel.ActinicLights( Port3 ); // Right Actinic Light power
    ReefAngel.DayLights( Port4 ); // Right Day Light power
    ReefAngel.StandardHeater( Port5 ); // Heater
    ReefAngel.SingleATOLow( Port6 ); // Auto top off
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer
    ReefAngel.PWM.Channel0PWMParabola(); // Left Actinic Light 0-10v
    ReefAngel.PWM.Channel1PWMParabola(); // Left Day Light 0-10v
    ReefAngel.PWM.Channel2PWMParabola(); // Right Actinic Light 0-10v
    ReefAngel.PWM.Channel3PWMParabola(); // Right Day Light 0-10v
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right Jebao RW4
    ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
troylong45
i need storm and geo location added and want the daylight and blue channel to storm but i want a 30min off set for the geo location sunrise in the relays and dimming ramping so i would like eveything normal in cloud and geo location beside relay 3 to have a 30 min delay from when relay 1 comes on and relay 4 to have 30 min delay from when relay 2 comes on and 30 mins after it goes off. and same goes for the dimming expansion so i would like a 30min delay from channel 2 and 0 and 30 min delay between 3 and 1
