smoothing out led dimming
PostPosted: Wed Nov 04, 2015 4:37 pm
is there a way to smoooth out the dimming?
I have the pwm expansion running ldd drivers.
you can see the steps as it dims, Id like to smooth it out so it slowly drops down like the sun rather step down... is this possible?
Adam
58 Gal
PostPosted: Wed Nov 04, 2015 7:14 pm
As long as its not a really old dimming expansion you should be able to use the new highres dimming that gives us 4096 steps instead of 256. Can you post your code? When was the last time you updated your libraries and ra?
PostPosted: Wed Nov 04, 2015 7:15 pm
Even with the older module you'll actually get 256 steps rather than 100, which is still a big increase :)
PostPosted: Thu Nov 05, 2015 6:13 am
this is whats in there now, but will be changing it soon eliminated the dc pump as it doesnt work, stuck on constant 30% never changed.
and adding delay to when certain channels start coming on for sun rise effect.
I built a new 180gal 48x30x30 tank and large sump with new equipment. so codes needs to be redone.
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.DCPump.FeedingSpeed=30;
    ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
    ReefAngel.Relay.On( Port7 );
     //Use PH Flexible Calibration
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.DayLights( Port8 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel1PWMSlope();
    ReefAngel.PWM.Channel2PWMSlope();
    ReefAngel.PWM.Channel3PWMSlope();
    ReefAngel.PWM.Channel4PWMSlope();
    // Add random mode if we set to Mode to Custom in portal
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
    if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
    rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3600) {
    // Continue NTM for the 60 minutes
    ReefAngel.DCPump.Mode=NutrientTransport;
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Constant;
    ReefAngel.DCPump.Speed=30;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
    ReefAngel.Portal( "ademster" );
Adam
58 Gal
PostPosted: Thu Nov 05, 2015 6:41 am
Good news. The code you are using will support the high resolution dimming. You just need to make sure you're on the latest libraries and re-upload. You should get either double or ~400x resolution.
PostPosted: Sat Nov 07, 2015 6:51 am
so simply updating the libs and uploading the new code will give me the better resolution on dimming?
Adam
58 Gal
PostPosted: Sat Nov 07, 2015 3:20 pm
It should. It was added into the last release and should be transparent based on your code.
PostPosted: Sun Nov 08, 2015 8:29 pm
I think he will need a code change.
PostPosted: Sun Nov 08, 2015 8:48 pm
Why? He'a using ReefAngel.PWM.ChannelXSlope() those functions call the HighRes functions behind the scenes. What code would need to change?
PostPosted: Sun Nov 08, 2015 8:52 pm
It calls the high res behind the scenes, but the resolution is still 0-100 steps, which gets upscaled, I think.
He would need to use the raw numbers 0-4096 to be able to take advantage of the high resolution.
Next
Return to Requests
