Jebao wavemaker
Jebao wavemaker
my question is, if I use the jebao cable is there a way to have the pumps on a certain mode with a certain max percentage be able to run lets say from 8 am to 9 pm and while running that certain mode.. be able to ramp up and down through the percentages with it hitting max at mid day?
Re: Jebao wavemaker
Yup. I think you could use the PWMSlope function and feed it to the pump function.
Re: Jebao wavemaker
Ok, I saw that you could tie it in with the parabola selection of the actinic or white channel. I am a potential buyer but am curious of things like this before I pull the trigger as im not great at codes.
Re: Jebao wavemaker
You could do it independently of the lights as well.
Re: Jebao wavemaker
Yeah, you can basically create whatever waveform you can think of.
We have the basic waveforms like the ecotech waveforms and to add to that, we also have slopes, parabolas, sigmoids and else wafeforms. There may be more that I can't think of.
Re: Jebao wavemaker
great! will play with it when I get it in I will come here for help. I can think of some advanced usages for it but no sense in asking now, im sure its more than capable.
Re: Jebao wavemaker
I am generating my code in anticipation of my order, if I post here could you help me develop a code to add in to perform the way I would like.
I am thinking:
from 9 am to 7 pm - alternate back and forth randomly maybe reef crest? (I can set a % that I would like it to stay at, and it can choose to go something like 20% over or under.. or anywhere in between that 40 percent range at its choice)
from 7pm - 9am - alternate back and forth for 20 minutes at a time at the lowest possible percentage
is something like that possible?
I am thinking:
Re: Jebao wavemaker
ReefAngel.FeedingModePorts = Port2Bit;
ReefAngel.WaterChangePorts = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,764,771 );
ReefAngel.SingleATO( true,Port2,200,0 );
ReefAngel.MHLights( Port3,21,0,9,0,10 );
ReefAngel.StandardLights( Port4,9,0,19,0 );
ReefAngel.MHLights( Port8,12,0,15,0,7 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,15,48,15) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,15,48,15) );
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
ReefAngel.AddWifi();
