pretty much what the subject says...what are the connectors called that would plug into the pwm connector...i want to solder on a connector and plug into the reef angel.
thanks
pwm pin connector
dmolton
Re: pwm pin connector
As per Roberto awhile ago on the google groups:
1st Gen Relay box - Digikey part #: A98223-ND
2nd Gen Relay box - Digikey part #: 2510-02-ND
