Feed and water change not working
slm222
Post by slm222 »
Good morning all,
I added a custom wave function I found on the site, its working great but since I changed it my water change/feed mode is not turning off the jebao wavemakers. Could someone please let me know where I went wrong?
    ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit;
    ReefAngel.Relay.On( Port7 );
    // Define labels for 2014 LCD screen
    //box0
    ReefAngel.CustomLabels[0]="T5HO";
    ReefAngel.CustomLabels[1]="Skimmer";
    ReefAngel.CustomLabels[2]="FugeLight";
    ReefAngel.CustomLabels[3]="Heater";
    ReefAngel.CustomLabels[4]="ScrubLight";
    ReefAngel.CustomLabels[5]="Unused";
    ReefAngel.CustomLabels[6]="Return";
    ReefAngel.CustomLabels[7]="ATO_Pump";
    ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
    ReefAngel.MHLights( Port2,5,0,22,0,5 ); //skimmer
    ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
    ReefAngel.StandardHeater( Port4,780,788 ); //heater
    ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
    ReefAngel.SingleATO( true,Port8,300,0 ); // ato
// Wave Makers
if (hour()>=7 && hour()<10)
{ ReefAngel.PWM.SetDaylight( SineMode(0,100,300,true) ); // Long pulse at 100% with 300s pulse on sync mode
  ReefAngel.PWM.SetActinic( SineMode(0,100,300,false) ); // Long pulse at 100% with 300s pulse on anti-sync mode }
else if (hour()>=10 && hour()<12)
{ ReefAngel.PWM.SetDaylight( SineMode(0,100,180,true) ); // Sine Wave at 100% with 180s pulse on sync mode
  ReefAngel.PWM.SetActinic( SineMode(0,100,180,false) ); // Sine Wave at 100% with 180s pulse on anti-sync mode }
else if (hour()>=12 && hour()<15)
{ ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% +/- 20% on anti-sync mode }
else if (hour()>=15 && hour()<17)
else if (hour()>=17 && hour()<20)
{ ReefAngel.PWM.SetDaylight( SineMode(0,35,400,true) ); // Sine Wave at 35% with 300s pulse on sync mode
  ReefAngel.PWM.SetActinic( SineMode(0,35,400,false) ); // Sine Wave at 35% with 300s pulse on anti-sync mode }
Lionfan
Re: Feed and water change not working
Post by Lionfan »
slm222 wrote:Good morning all,
    //box0
// Wave Makers
Your feeding speed command is set to DC.pump, but since you've done a custom code and your pumps are being run as PWM.Daylight, the controller doesn't know to turn the PWM channels down to 0.
I'm not good enough with Reef Angel to write the code you need to have the controller recognize that it needs to turn PWM channels to zero, but it should be as simple as an argument.
slm222
Post by slm222 »
thank you for the response. Found the proper coding to turn off the pumps.
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
 ReefAngel.PWM.SetActinic(0);
 ReefAngel.PWM.SetDaylight(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
