Scale or Pressure
PostPosted: Fri Nov 20, 2015 6:41 am
lnevo wrote:Wow I hadn't considered what Alan had said about using the ph to control the solenoid and then with the pressure guage monitoring the tank you'd maintain a pretty rock solid reactor setup...so we have 150 for the sensor, 110 for a ph expansion. Figure around 350 for a full solenoid/ph/digital gauge. We already have the functions pretty much to have a completely integrated calcium reactor setup.
Sounds reasonable!! The regulator I got was $300 no pH control
PostPosted: Fri Nov 20, 2015 1:19 pm
And no digital gauge. :)
PostPosted: Fri Nov 20, 2015 2:05 pm
How about a continuous duty peristaltic pump? Controlled by RA, not that would be the ultimate controllable CALRx Rig.
PostPosted: Fri Nov 20, 2015 5:52 pm
You could add the RA dosing pump or the ATO one to the mix...
PostPosted: Tue Dec 01, 2015 10:01 am
lnevo wrote:You could add the RA dosing pump or the ATO one to the mix...
Are these continuous duty?
Anyone working on this? Would be great just to have a controllable solenoid. Big market for those and CALRx
PostPosted: Tue Dec 08, 2015 2:16 pm
I doubt it. That's why there's such a huge demand in the reefing community for things like Cole parmer masterflex pumps.
PostPosted: Tue Dec 08, 2015 8:58 pm
Do you need continuous duty for a cal reactor?
Its mostly AWC that I've seen for continuous duty.
PostPosted: Thu Dec 10, 2015 8:12 am
All suggestions on the Reef Forums is for a continuous flow of water through the Reactor, around 30 ml/hr.
I run a line with my return pump. Would love to be able to control the flow. Right now I am limited to counting drip rate and estimating the flow with eyeball flow meter.
Controllable continuous duty peristaltic pump!!! This would be my ideal.
PostPosted: Thu Dec 10, 2015 8:14 am
The pump should be sub $300 price point. I paid about $250 for a used Cole Palmer and it crapped out in about 6 months. Would be willing to pay about 300-400 for a controllable one.
PostPosted: Thu Dec 10, 2015 9:38 am
What is continuous duty and why are they different?
If it is continuous, I would imagine it is not controllable or it would be called variable duty, no?
PreviousNext
Return to Requests
