Random Wave Mode help
Ask in here.
slm222
Post by slm222 »
I copied Saochen's code and made some modifications, could yall look over and let me know if it looks like it will work and accomplish what is listed out in the comments?
static int rmode;
byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, LongPulse, Else, };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) { //does it go to this after a feeding mode??
} else if (now()%SECS_PER_DAY<75600 || now()%SECS_PER_DAY>=32400) { // 9pm / 9am
  // Night mode (go to 30%)
  ReefAngel.DCPump.Mode=TidalSwell;
  ReefAngel.DCPump.Speed=35;
} else if (now()%SECS_PER_DAY<32400 || now()%SECS_PER_DAY>=36000) { // 9am / 10am
  // Transition to random from Night  (go to Tidal Swell  100%)
  ReefAngel.DCPump.Speed=100;
}else if (now()%SECS_PER_DAY<68400 || now()%SECS_PER_DAY>=75600) { // 7pm / 9pm
  // Transition From random to night mode (go to Tidal Swell 100%)
}else if (InternalMemory.DCPumpMode_read()==11) {
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
slm222
Re: Random Wave Mode help
Post by slm222 »
I don't know why but it doesn't seems to be working. runs into an issue when it gets to byte modes[] the fifth line down.
What is it doing or not doing?
I notice an extra comma after the else in the byte modes[]. Could be causing an unexpected behavior.
cosmith71 wrote:I notice an extra comma after the else in the byte modes[]. Could be causing an unexpected behavior.
that should not make a difference but it could.
slm222
Post by slm222 »
This is the first error I'm running into, see attached picture
Heres the current code I'm trying
static int rmode;
byte modes[] = { ReefCrestMode, SineMode, TidalSwellMode, LongPulseMode, ElseMode, };
changeMode=false;
} else if (now()%SECS_PER_DAY>=75600 || now()%SECS_PER_DAY<=32400) { // 9pm / 9am
} else if (now()%SECS_PER_DAY>=32400 || now()%SECS_PER_DAY<=36000) { // 9am / 10am
}else if (now()%SECS_PER_DAY>=68400 || now()%SECS_PER_DAY<=75600) { // 7pm / 9pm
} else {
Yes it's definitely the extra comma. The compiler is expecting a byte value there but you're not providing one.
slm222
Post by slm222 »
I took out the extra comma and its still giving me the same error: invalid conversion from 'byte(*)(byte, byte, Boolean)' to 'byte'
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
    ReefAngel.Relay.On( Port7 );
    // Define labels for 2014 LCD screen
    //box0
    ReefAngel.CustomLabels[0]="T5HO";
    ReefAngel.CustomLabels[1]="Skimmer";
    ReefAngel.CustomLabels[2]="FugeLight";
    ReefAngel.CustomLabels[3]="Heater";
    ReefAngel.CustomLabels[4]="ScrubLight";
    ReefAngel.CustomLabels[5]="Unused";
    ReefAngel.CustomLabels[6]="Return";
    ReefAngel.CustomLabels[7]="ATO_Pump";
    ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
    ReefAngel.MHLights( Port2,5,0,22,0,5 ); //skimmer
    ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
    ReefAngel.StandardHeater( Port4,780,788 ); //heater
    ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
    ReefAngel.SingleATO( true,Port8,360,0 ); // ato
static int rmode;
byte modes[] = { ReefCrestMode, SineMode, TidalSwellMode, LongPulseMode, ElseMode };
changeMode=false;
} else {
Take out Mode from the Mode names. Those are the functions not the "mode" so replace ReefCrestMode with ReefCrest
slm222
Post by slm222 »
ahh. That seems to have fixed it. I will try it tonight and see how it goes. Thank you very much for the help. I will report back.
slm222
Post by slm222 »
Ok, added a couple things. Notices the pumps were running in sync, so added sync and anti sync in each profile and added duration for the modes that transition from and to night ( sine ) . seems to be working good so far. What unit of time is used for sine in the duration I set?
static int rmode;
byte modes[] = { ReefCrest, Sine, TidalSwell, LongPulse, Else, Sine, ReefCrest, Else };
changeMode=false;
  // after feed mode Continue NTM for the 60 minutes
  ReefAngel.DCPump.Mode=Sine;
    ReefAngel.DCPump.Duration=600;
    ReefAngel.DCPump.Duration=400;
} else {
You don't have to do the assignment if sync/antisync so many times. You can do it once before the if statement or even put it in setup.
slm222
Post by slm222 »
got ya. seems to be working. but has been coming up with reef crest everyday. should this work without connecting to it through the portal and set random everyday?
I changed my randomizing frequency to every 6 hours because daily wasn't giving enough of a change :)
slm222
Post by slm222 »
heres something I just noticed. ive tried two different variations of the code.
with this code it stays in tidal swell mode
static int rmode;
changeMode=false;
} else {
in this code it goes to random, but im trying to figure out how you stated above to change change rate to every 6 hours
static int rmode;
changeMode=false;
} else {
Are you seeding the random number generator? Otherwise it will pull the same random sequence every time you restart the controller
slm222
Post by slm222 »
Thank you for such quick and helpful responses!
no im afraid with my lack of programming knowledge I wouldn't know how or where to do that.
This is what I have in my setup() function.
randomSeed(now()/SECS_PER_DAY);
This gives it something to randomize against and since I'm doing it by day it will be the same if I reboot that day
slm222
Post by slm222 »
any idea on why the code here would stay on sine instead of going to random ?
static int rmode;
changeMode=false;
} else {
Well there's only a 1 in 4 chance of it and second, it's going to be the same all day. Did you add the randomseed function. You can take out the / seconds per day part and it should be more random. Also know that the portal only updates every 5 minutes
slm222
Post by slm222 »
Yes I added it in the void setup() area.
Currently I don't have access to the portal. I have not ordered my WiFi unit yet. Will that cause issues?
No it won't cause issues. Just wasn't sure how you were monitoring the mode.
slm222
Post by slm222 »
Oh. I look on the screen when I remember.
slm222
Post by slm222 »
so in your thought theres no way to do what I was trying to do? which was
morning of sine 7am-9am
Afternoon of random 9am-8pm
evening of sine 7pm-9pm
and then nighttime mode 9pm-7am
Of course there is. We can do anything. Look at Steve's code (Sacohen) he's doing that I believe.
slm222
Post by slm222 »
Haha. I love the confidence. that's one reason why I went with reefangel! this community is great.
Steve's seems to just go from night time to the random code. I tried it in my code, but it seems to just stay in sine mode.
Ok...i also want to make sure it's changing for you or still staying sine
slm222
Post by slm222 »
ok. I will keep an eye on it over the holidays and report back. heres the code im running. I change secs to hours. seems to be working right. Is this a reason for the time to be in seconds instead of hours?
static int rmode;
byte modes[] = { TidalSwell, ReefCrest, TidalSwell, Lagoon, Else, ReefCrest, Else, Lagoon };
changeMode=false;
if (now()-feeding<1800) {
else  if (hour()>=7 && hour()<9){
  //morning
  ReefAngel.DCPump.Duration=300;
else if (hour()>=9 && hour()<19) {
  //9am to 7pm
  ReefAngel.DCPump.Speed=95;
else  if (hour()>=19 && hour()<21){
  //7pm to 9pm
}else  { // 9pm / 9am
  // Night mode
  ReefAngel.DCPump.Duration=500;
  ReefAngel.DCPump.Speed=40;
You realize you hve the schedule all setup at the end. From 7pm to 9am you are forcing sine mode. The only time you are using the random mode is between 9am and 7pm
slm222
Post by slm222 »
yes sir. I think that's what I was trying to do. just not sure if I did it right
this is how im seeing it in my mind :
7am-9am - sine wave (ramping up to the random mode)
9am-7pm - RANDOM
7pm-9pm - sine wave (ramping down from the random mode)
rest of the night sine wave at 40%
