Help With my build - PWM Expansion
tyson_mitchell_88
Please any help would be greatly appreciated. I have been using the wizard up to this stage, with limited custom script, but have recently installed a PWM expansion and would like to take over manually on the scripting.
Happy with everything apart from the PWM expansion atm.
Last edited by tyson_mitchell_88 on Thu Dec 31, 2015 3:36 pm, edited 1 time in total.
Re: Help With my build - PWM Expansion
What is it you aren't happy with and what is it you want do?
tyson_mitchell_88
I would like to set the parameters for the PMW expansion. My experience so far has been copy and paste. I'm guessing something like this.
ActinicPWMValue=PWMSlope(5,00,21,00,0,100,180,ActinicPWMValue);
DaylightPWMValue=PWMSlope(6,30,18,30,0,80,180,DaylightPWMValue);
CheckCloud();
CheckCloud();
Instead of SetActinic and SetDaylight, you are going to use SetChannel(X, ActinicPWMValue) where X is the channel you want to set.
- cosmith71
The CheckCloud routine needs an overhaul, too. What channels on the expansion are you wanting to use for blues and for whites?
tyson_mitchell_88
This what I have so far mate, using channel 0 for whites and 1 for actinics. I also have acticics on 4 and 5 for moon.
Last edited by tyson_mitchell_88 on Thu Dec 31, 2015 3:37 pm, edited 1 time in total.
- cosmith71
What's on 2 and 3?
And what kind of drivers are you using?
tyson_mitchell_88
Using meanwell LPF drivers on expansion and ELN on standard. Have uvs on channel 2 and 3.
- cosmith71
What do you want to flash with the lightning?
tyson_mitchell_88
I would like to use whites on the standard and channel 0, 4 and 5 on the expansion.
Thanks for helping me out mate.
Last edited by tyson_mitchell_88 on Thu Dec 31, 2015 3:41 pm, edited 1 time in total.
tyson_mitchell_88
This is were I am at atm
#include <Moon.h>
//Standard Dimming//
int ActinicPWMValue=0; // For cloud code
int DaylightPWMValue=0; // For cloud code
//Dimmer Expansion//
int WhitePWMValue=0;
int SupPWMValue=0;
int MoonPWMValue=0;
InternalMemory.LCDID_write(0);
ReefAngel.AddORPExpansion(); // ORP Expansion Module
ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit;
ReefAngel.WaterChangePortsE[0] = Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardHeater( Port2 );
ReefAngel.StandardFan( Port4 );
ReefAngel.DayLights( Port7 );
ReefAngel.ActinicLights( Port8 );
ReefAngel.SingleATOHigh( Box1_Port2 );
ReefAngel.DayLights( Box1_Port5 );
//Display in Failsafe//
ReefAngel.Relay.On(Box1_Port8);
ReefAngel.Relay.Off(Box1_Port8);
//Lighting Control//
ActinicPWMValue=PWMSlope(5,00,21,00,15,100,180,ActinicPWMValue);
DaylightPWMValue=PWMSlope(6,30,18,30,15,70,180,DaylightPWMValue);
CheckCloud();
//Lighting expansion control//
WhitePWMValue=PWMSlope(6,30,18,30,0,100,180,WhitePWMValue);
SupPWMValue=PWMSlope(6,30,18,30,0,100,240,SupPWMValue);
MoonPWMValue=PWMSlope(21,00,5,00,0,100,200,MoonPWMValue);
ReefAngel.PWM.SetChannel( 0, WhitePWMValue);
ReefAngel.PWM.SetChannel( 1, ActinicPWMValue);
ReefAngel.PWM.SetChannel( 2, SupPWMValue);
ReefAngel.PWM.SetChannel( 3, SupPWMValue);
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
ReefAngel.Portal( "tyson_mitchell_88" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(6,30)
#define End_Cloud_Before NumMins(18,30)
#define Lightning_Change_per_Cloud 60
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Slow, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Calm, Calm, Calm, Slow, Slow, Slow, Slow, Slow, Mega, Mega2 };
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255)); // Flash on
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
analogWrite(daylightPWMPin,DaylightPWMValue*2.55); // Flash off
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
wdt_reset();
break;
case Fast:
wdt_reset();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
- cosmith71
Give this a try. It was major surgery.
It compiles, but I can't test it otherwise. Let me know how it works.
#include <Moon.h>
int SupPWMValue=0;
int MoonPWMValue=0;
CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
byte n;
int newdata;
byte a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (byte i=0; i<a; i++)
// Flash on
analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255)); // Flash on daylight port
newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 0.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
Wire.write(0x8+(4*4)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 4.
Wire.write(0x8+(4*5)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 5.
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValue(0); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
Wire.write(0x8+(4*1));
newdata=ReefAngel.PWM.GetChannelValue(4); // Use the channel number you're flashing here
Wire.write(0x8+(4*2));
newdata=ReefAngel.PWM.GetChannelValue(5); // Use the channel number you're flashing here
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
if (n>cend) return (int) PWMStart;
tyson_mitchell_88
Loaded it up this morning, everything so far so good.
Only thing is my lcd is is staying black again. I added in InternalMemory.LCDID_write(0); to setup a while back which fixed it, but same problem again.
tyson_mitchell_88
My white and actinic on standard dimming haven't turned off and I haven't noticed any storm action today either.
- cosmith71
I just noticed a couple of things. I'll see if I can fix them tomorrow.
Not sure why the standard ports aren't dimming.
tyson_mitchell_88
The standard ports will turn off, but I have to reboot the angel after off times.
tyson_mitchell_88
tyson_mitchell_88
Also Current build
#include <Moon.h>
int SupPWMValue=0;
int MoonPWMValue=0;
ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port7Bit | Port8Bit;
//boosterpump//
ReefAngel.Relay.Off(Box1_Port2);
ReefAngel.Relay.On(Box1_Port2);
MoonPWMValue=PWMSlope(21,00,5,00,0,MoonPhase(),200,MoonPWMValue);
CheckCloud();
ReefAngel.PWM.SetChannel( 4, MoonPWMValue);
ReefAngel.PWM.SetChannel( 5, MoonPWMValue);
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
byte n;
int newdata;
// Flash on
newdata=4095;
cstart*=60;
cend*=60;
}- cosmith71
Not sure why the standard ports would be staying on. You may need to reduce the minimum value in your PWM slope. Looks like it's set for 15.
This should fix the lightning.
#include <Moon.h>
int SupPWMValue=0;
int MoonPWMValue=0;
//boosterpump//
CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
WhitePWMValue=DaylightPWMValue;
MoonPWMValue=DaylightPWMValue;
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
byte n;
int newdata;
// Flash on
analogWrite(daylightPWMPin,255); // Flash on daylight port
newdata=4095;
cstart*=60;
cend*=60;
tyson_mitchell_88
Just to check myself is this how the command works.
on 5, off 9, min 15, max 100, ramp 180, outside on off value(0).
thanks
thanks
- cosmith71
tyson_mitchell_88
Hi Colin, I have changed the cloud / lightning to not activate channels 4 & 5 on the expansion. Are you please able to run you eyes over just to make sure its all good?
#include <Moon.h>
byte ActinicPWMValue=0; // For cloud code
byte DaylightPWMValue=0; // For cloud code
byte WhitePWMValue=0;
byte Actinic1PWMValue=0;
byte SupPWMValue=0;
byte MoonPWMValue=0;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Box1_Port6);
ReefAngel.StandardHeater( Port2,220,225 );
ReefAngel.StandardLights( Port3,8,00,16,00);
ReefAngel.StandardFan ( Port4,230,238 );
ReefAngel.StandardLights( Port7,21,00,5,00 );
ReefAngel.StandardLights( Port8,5,00,21,00 );
ReefAngel.StandardLights( Box1_Port5,8,00,16,00 );
//White off
if (hour()==18 && minute()==30 && second()>=0 && hour()==18 && minute()==30 && second()<2)
ReefAngel.Relay.Off(Port8);
} else {
//boosterpump//
DaylightPWMValue=PWMSlope(6,30,18,30,0,70,180,DaylightPWMValue);
WhitePWMValue=PWMSlope(6,30,18,30,0,60,180,WhitePWMValue);
Actinic1PWMValue=PWMSlope(5,00,21,00,0,80,180,Actinic1PWMValue);
SupPWMValue=PWMSlope(8,00,16,00,0,80,200,SupPWMValue);
MoonPWMValue=PWMSlope(21,00,5,00,0,30,235,0);
CheckCloud();
ReefAngel.PWM.SetChannel( 1, Actinic1PWMValue);
//Waterchange Mode
static time_t wc_drain=0;
static time_t wc_tankoff=0;
static time_t wc_tankup=0;
static time_t wc_refill=0;
static int stage=0;
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE || (hour()==18 && minute()==0 && second()==0))
{ // At 6pm every day the following to occur or when WC mode is activated
wc_tankoff=now();
stage=1;
if (now()-wc_tankoff < 300 && stage==1)
ReefAngel.Relay.Off(Box1_Port7);
} else {
wc_drain=now();
wc_tankoff=0;
// stage=2;
// if (now()-wc_drain < 300 && stage==2)
// if (ReefAngel.HighATO.IsActive())
// ReefAngel.Relay.On(Box1_Port4);
// else
// ReefAngel.Relay.Off(Box1_Port4);
// } else {
// wc_tankup=now();
// wc_drain=0;
// stage=3;
// if(now()-wc_tankup < 300 && stage==3)
// ReefAngel.Relay.On(Box1_Port7);
// ReefAngel.Relay.On(Box1_Port8);
// } else {
// wc_refill=now();
// wc_tankup=0;
// stage=4;
// if (now()-wc_refill < 300 && stage==4)
// ReefAngel.Relay.Off(Box1_Port1);
// else
// ReefAngel.Relay.On(Box1_Port1);
// } else {
//ButtonPress++;
// wc_refill=0;
// stage=0;
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
byte n;
int newdata;
// Flash on
newdata=4095;
cstart*=60;
cend*=60;
Last edited by tyson_mitchell_88 on Sat Jan 23, 2016 5:55 am, edited 1 time in total.
- cosmith71
Here you go. Made one change in the Strike routine to properly de-flash channel 0.
#include <Moon.h>
byte SupPWMValue=0;
//boosterpump//
CheckCloud();
//White off
} else {
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
//MoonPWMValue=DaylightPWMValue;
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
byte n;
int newdata;
// Flash on
newdata=4095;
cstart*=60;
cend*=60;
tyson_mitchell_88
tyson_mitchell_88
Hi Colin, for some reason channels 4 & 5 are still activating in storms.
- cosmith71
Made an edit. Try the above code again.
tyson_mitchell_88
