RA ruined my ATI fixture
Lionfan
Post by Lionfan »
Out of nowhere my RA started randomly and violently clicking power on and off to one of the modules. Considering I just got a replacement Relay Expansion and the expansion hub is only a few weeks old, theyre not the problem.
I'm about done with RA.
Now, after the power flashes, all 3 of my ballasts are blown, and its going to cost me $180 to fix it.
So, what could have been the problem?
Re: RA ruined my ATI fixture
Was it the main box or expansion that was doing that?
Lionfan
Post by Lionfan »
rimai wrote:Was it the main box or expansion that was doing that?
Expansion
Did you use the new USB cable that came with the new hub?
This seems to be a bad connection somewhere.
Could it be in the USB port in the main box?
Lionfan
Post by Lionfan »
rimai wrote:Did you use the new USB cable that came with the new hub?
That could be it.
I used the new USB cord.
I have a another RA set up, and I can switch the relay boxes to see if that's causing it.
It's not as crazy as it was, but it is still randomly cycling power, and it now i have random dimming flashes.
Lionfan
Post by Lionfan »
Im starting to notice that I only get the power blinking when my daylights are on.
Do you think there is too much power getting pulled thru the relay expansion?
Not sure what's happening with the dimming blinking, but it might explain the power cycles
Whenever there is a bus lock, the dimming channel may do that.
Lionfan
Post by Lionfan »
rimai wrote:Whenever there is a bus lock, the dimming channel may do that.
So a bus lock is causing the power cycles?
That's what I'm thinking.
Lionfan
Post by Lionfan »
rimai wrote:That's what I'm thinking.
So what could be causing the bus lock I wonder? Most everything is new.
Except the water level sensor.
I'll unplug it tonight and see how it acts tomorrow
