why to code to memory
PostPosted: Sun Jan 17, 2016 9:31 pm
im wondering what the benefits are to doing this rather than just doing it the way the wizard programs it in
PostPosted: Thu Jan 21, 2016 10:14 am
slm222 wrote:im wondering what the benefits are to doing this rather than just doing it the way the wizard programs it in
I believe it is so you can make changes on the fly via the web app or Smartphone. If you store it in the code only, you will have to plug in and reprogram to make any changes.
PostPosted: Thu Jan 21, 2016 7:08 pm
oneboss302 wrote:I believe it is so you can make changes on the fly via the web app or Smartphone. If you store it in the code only, you will have to plug in and reprogram to make any changes.
yup, that is the primary reason. you are correct.
PostPosted: Thu Jan 28, 2016 7:43 am
just saw I never replied. Thank you guys. If I start coding to memory would I be required to use another program to modify things in the future?
PostPosted: Fri Jan 29, 2016 5:00 am
Yep. Either one of the apps or the Portal.
Return to For New Members
