why to code to memory
slm222
im wondering what the benefits are to doing this rather than just doing it the way the wizard programs it in
oneboss302
Re: why to code to memory
slm222 wrote:im wondering what the benefits are to doing this rather than just doing it the way the wizard programs it in
I believe it is so you can make changes on the fly via the web app or Smartphone. If you store it in the code only, you will have to plug in and reprogram to make any changes.
- Contact:
yup, that is the primary reason. you are correct.oneboss302 wrote: I believe it is so you can make changes on the fly via the web app or Smartphone. If you store it in the code only, you will have to plug in and reprogram to make any changes.
slm222
just saw I never replied. Thank you guys. If I start coding to memory would I be required to use another program to modify things in the future?
- cosmith71
Yep. Either one of the apps or the Portal.
