Ok Guru,
Came home tonight to find my client not updating and a Red light on the Wifi Adapater. When power is cycled to the adapter the all 4 led flash but the red stay on but dim.
Any Ideas?
Please advise
Don
Red light on Wifi adapter
Re: Red light on Wifi adapter
Would you be able to use Tera Term to check if you can enter command mode?
When you use Tera Term or the wifi utility, the orange LED should blink when there is communication between them. Does it blink?
Can you also try to factory reset it using the jumper method?
divingdon
Sorry I should have posted that I tried the factory hard reset and nothing and I also tried to connect using the terra term software and nothing it didn't respond to the the $$$ command.
