Some strange issues
Some strange issues
Good morning Reef Junkies!
I've always considered myself a geek, but this programming piece has me feeling a little skiddish and insignificant!
I'm a newbie in the RA work (RA+) and just got my system setup a week ago. I don't have any adapters or modules yet, but I will be looking to get the wireless one in Feb. When I use the wizard to code setup for my lights, I am getting some funky irregularities. I can set on and off times, but it only want to work on occasion.
My questions/issues of concern:
First, the other day the system just completely shut itself off and turned off anything attached to it. It was like it just lost power, display was dead, no power to anything in the unit. Everything I plugged into the outlet worked. I unplugged everything, put it all into a normal power bar and all my equipment was ok. I looked at the module and power box and nothing seemed to be wrong. Next morning I hooked everything back up and it has worked fine.
I unscrewed the unit and there appears to be a small singe type mark on the primary board attached to the joystick. When I plugged it back in, the display was asci characters until I re-ran the wizard and the display seemed to correct itself. I took a fine bristle brush (dry) and gently cleaned it off. So far so good. Ill keep an eye on this and send it back if it continues.
Secondly, my lighting. I am in the process of changing to LED's, but I currently have a Aqualife pro 72 MH(3x150)T5 combo. My lighting works well except for moon light (4 led's built into the system (Plug 1) and a modular LED light bar plugged into port 2. (actinics are on 2 and MH/T5 are on 4) When I put in the code for
Its not exactly right, I'm trying to do this from memory while on break at work
(Moon Lights)
StandardLights ... port1 (,5,00,9,00) ;(19,00,22,00) ;
StandardLights ... port2 (,5,45,9,00) ;(19,00,22,45) ;
etc...
The lights will turn on and off at the correct times, until Saturday, when they didn't want to come on any more in the evening. I reloaded the base program, ran the wizard and then edited the code again, it wouldn't work. (Note, this is after the unit mysteriously shut itself off.)
Do you think there is a problem with the controller?
(Moon Lights)
etc...
Re: Some strange issues
Post your code.
Does the screen show the appropriate outlets have switched on? How many total amps does that MH/T5 fixture draw?
Collin,
Sorry for the delay in my reply, I was helping host a Frag Swap so needless to say, its been a busy weekend.
I had ZERO power, no outlets, no RA power... Nothing.
The problem was a faulty cord. I took another cord from my computer hardware supplies and the problem disappeared..
Ill post my code later tonight when I get home.
Jeremiah
Jeremiah
cosmith71 wrote:Post your code.
My Code:
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port1,5,0,10,0 );
ReefAngel.StandardLights( Port1,19,00,22,45 ) ;
ReefAngel.StandardLights( Port2,5,45,10,0 );
ReefAngel.StandardLights( Port2,19,00,22,00 ) ;
ReefAngel.StandardLights( Port3,9,55,20,30 );
ReefAngel.StandardLights( Port4,12,0,20,0 );
ReefAngel.StandardHeater( Port7,760,780 );
Hmmm. I'm not sure you can do two StandardLights for the same port.
Try this:
Try this:
if ((hour() >= 5 && hour() < 10) || (hour() >=17 && (hour() < 22 && minute() < 45)))
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
if (((hour() >= 5 && minute() >= 45) && hour() < 10) || (hour() >= 19 && hour() < 22))
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
Thanks, I will try this when I get home.
I am getting this error when I post the code. Its changed slightly, did I miss something?
Watchdog Timer
Version Menu
2014 Main Screen
Standard Menu
sketch_jan27a.cpp: In function 'void loop()':
sketch_jan27a:76: error: expected `)' before '{' token
sketch_jan27a:79: error: expected `)' before 'else'
Code:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
if (((hour() >= 5 && minute() >= 45) && hour() < 10) || (hour >= 19 && hour() < 22))
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.Off(Port3);
ReefAngel.StandardHeater( Port7,780,800 );
Watchdog Timer
Version Menu
2014 Main Screen
Standard Menu
Code:
Yeah, this part. You have extra parentheses. Just click "Select All" on the code I posted, copy, then paste into Arduino.
Same Error
***Here is where it states the error is***
- See screen Capture
- Error.jpg (148.29 KiB) Viewed 8027 times
Sorry, Like I said i am new.. Please bear with me.
I didn't realize I wasn't copying the editor
if (((hour() >= 5 && hour() < 10) || (hour() >=17 && (hour() < 22 && minute() < 45))
Stupid parentheses.
I was trying, resolved the first one, but couldn't figure out the second set.
My Wifi Controller should come tomorrow, so i might change up a little, but what you've helped me with is beginning to make sense. Hopefully I can do a little coding (sheer attempt at this point) this weekend and see what I can come up with.
Thanks again! Sincerely Appreciated!!!
