bboss wrote:I cannot to get this App to work either. Both my iPhone 5C and iPad Mini return status.html timeout, forum ID not been set, and invalid forum username. I just got my WiFi attachment, configured it and portal is working great.
The App was downloaded from Apple App Store, my iOS version is 9.1on my iPad mini, 9.0.2 on my iPhone.
Am I missing some setting here? Thanks.
I have the same issue on hand. My friend can connect with no issue on his android phone.
The app works fine on wifi and normal IP address but when i use my "mydns" it gives the same error as bboss mentioned.
Ok there are some issues with ios9. Email Roberto to get access to the dev version.
Also if you load the dev code, the latest uapp is built into the controller. So if your port forwarding is good you could browse to http://ip.of.controller/wifi
I just updated my app on my phone and it erased my info so I plugged it back in. now I can access the internal memory and clear status but my relay and status icons don't load. keeps saying disconnected.
