What heater do you like?
paperdesk
Post by paperdesk »
What heater(s) do you like to use with your Reef angel controller?
I've gone through a few, and haven't found any I'm really excited about.
Ted
Lionfan
Re: What heater do you like?
Post by Lionfan »
I always use Finnex titanium tubes on my tank.
+1 finnex titanium. -100 via aqua titaniums (they reset to 78 degrees on power reset and also were a degree off)
paperdesk
Post by paperdesk »
Do you use the TH-S series? It looks like there is also a TH and an HMS series.
Ted
No problems with the Finnex. You just need the tube, not one with any sort of temp control.
I use the one with the temp controller. It's good backup to have a second thermostat
paperdesk
Post by paperdesk »
True, I almost cooked my tank once when the temp probe got pulled out of the water! I was thinking about adding a second temp probe.
Second temp probe is fine but a bus lock could prevent communication to the relay box and no matter how many probes you have would still not be able to shut off the port.
paperdesk
Post by paperdesk »
Yes, that makes a lot of sense, good plan.
