Hi All,
I have my 2 Jebao wavemakers connected via actinic and daylight ports using the wiring harness.
The actinic port (right wave) doesn't seem to be responding correctly. It is not turning off when supposed to, and the power level is incorrect. I woke up to a sandstorm this morning.
How can I troubleshoot this? Harness? Jebao ? ReefAngel port?
Help! JeBao's going crazy!
Re: Help! JeBao's going crazy!
Is this new or was it working previously. The one that's not working at all can you swap which jaebo its controlling? See if its the jaebo itself or the wiring harness/dimming port.
Smotz
Thanks, Lee.
It seems to of stabilized now.
I did all the basics - swapped harnesses, swapped ports, swapped Jebaos. I think the RA had a brain fart. I rebooted it a dozen times & re-uploaded the code.
Was weird.
Was weird.
