Jebao DC Modes
PostPosted: Sat Feb 20, 2016 12:21 pm
What are the parameters for Vtimer?
PostPosted: Sat Feb 20, 2016 12:44 pm
vtimer is duration. sorry
PostPosted: Sat Feb 20, 2016 1:02 pm
Yeah, but what is its range?
PostPosted: Sat Feb 20, 2016 1:04 pm
It will go for as fast as you want it to run.
duration of 1 will cause it to run at 100ms.
duration of 10 will cause it to run at 1s.
PostPosted: Sun Feb 21, 2016 10:17 am
Got it converted, not sure if I did the pull request right. I have trouble with GitHub.
PostPosted: Sat Apr 02, 2016 1:04 pm
rimai wrote:Here is a link of the modes inside the libraries.
viewtopic.php?f=7&t=2844
If you are using the DCPump class, here is a list of modes:
Constant
Lagoon
ReefCrest
ShortPulse
LongPulse
NutrientTransport
TidalSwell
Night
Storm
Custom
Gyre
Sine
Else
How long does it take to run through the modes? Assuming there is a start and end to the pattern before it starts over?
I've not really thought about it much but I started to think about this has I have two RW8's in my 40 breeder on opposite sides. What would happen if I had them alternate on/off with each pattern how that would look or even be beneficial...
PostPosted: Wed Nov 23, 2016 12:56 pm
has anyone got a way yet to set dc pumps in a storm like mode when cloud code for lights goes to lightning mode?
PostPosted: Wed Jan 04, 2017 2:27 pm
bump to learn more about storm and night modes!
PostPosted: Wed Jan 04, 2017 3:17 pm
Im trying to see if i can ramp the pwm channal as if it was a light channel i thing it should work . like make it 100% when cloud with lighting lile a hour or longer befor and after
PreviousNext
Return to Requests
