Progressive sunphase
Re: Progressive sunphase
No problem - the moonphase is actually part of the libraries. I just made that code so you can see what part of the moonphase its in visually on the main screen. Glad it worked out
HI-
SO I posted some strange behavior with my lights and the PWM ouput that I have been experiencing and Roberto mentioned that you have been working on a discovered bug which lead your lights to do, I am assuming, the same thing. I am still using your code until I can find more than 1 consecutive hour to work on the INO I am writing for the library calls and lat/lon based sunphase calculations... until then, I would love to see if you have figured this out and pirate your fix so my lights work unattended.
Hmmm late reply haha...I'll post update tonight
No worries.. I am finally getting around to finishing trouble shooting/debugging my code that uses the library functions for Lat/Lon sunrise sunset calc.. so I have not been running your code for a good while... just plug in and unplug for now, as I am constantly-the 0.25 days a week I have free time to do this
loading my code and serial debugging to be sure everything is working... which its not quite yet!
Thanks... still curious though...
- JNieuwenhuizen
My pwm function... wrong or right?
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDWhiteBlue0
#define LEDWhiteBlue1 1
#define LEDWhiteBlue2 2
#define Mixed LED 3
#define LEDMoonlights 4
// Initial values to all 6 PWM channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,};
//MoonPhase Value Setting
byte MoonPWMValue;
//------------------------------------------------ Start PWM Expansion Code for Slope ----------------------------------------------
PWMChannel[LEDWhiteBlue]=PWMSlope(
InternalMemory.StdLightsOnHour_read(),
InternalMemory.StdLightsOnMinute_read(),
InternalMemory.StdLightsOffHour_read(),
InternalMemory.StdLightsOffMinute_read(),
InternalMemory.PWMSlopeStartD_read(),
InternalMemory.PWMSlopeEndD_read(),
InternalMemory.PWMSlopeDurationD_read(),
0);
PWMChannel[Mixed LED]=PWMSlope(
InternalMemory.PWMSlopeStartA_read(),
InternalMemory.PWMSlopeEndA_read(),
InternalMemory.PWMSlopeDurationA_read(),
0);
ReefAngel.PWM.SetChannel(0,PWMChannel[LEDWhiteBlue]);
ReefAngel.PWM.SetChannel(1,PWMChannel[LEDWhiteBlue1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[LEDWhiteBlue2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[Mixed LED]);
ReefAngel.PWM.SetChannel(4,MoonPhase());
MoonPWMValue=MoonPhase();
if (hour()==22 || hour()==6)
MoonPWMValue=PWMSlope(22,00,7,00,0,MoonPhase(),60,0);
if (ReefAngel.PWM.ExpansionChannel[0]) MoonPWMValue=0;
ReefAngel.PWM.SetChannel(4,MoonPWMValue);
// PWMChannel[LEDWhiteBlue1]=PWMSlope(15,0,21,30,15,45,90,PWMChannel[LEDWhiteBlue1]);
PWMChannel[LEDWhiteBlue]=PWMSlope(8,0,22,0,0,90,300,PWMChannel[LEDWhiteBlue]);
PWMChannel[LEDWhiteBlue1]=PWMSlope(8,30,21,30,0,90,270,PWMChannel[LEDWhiteBlue1]);
PWMChannel[LEDWhiteBlue2]=PWMSlope(9,0,21,0,0,90,240,PWMChannel[LEDWhiteBlue2]);
PWMChannel[Mixed LED]=PWMSlope(12,0,18,0,0,90,60,PWMChannel[Mixed LED]);
// In the example above, we are starting the slope at 8:00am with 0% and going up to 90% within 300 minutes, which would be 5:00pm.
// Then it would stay at 90% from 13:00pm to 300 minutes prior to 10:00pm, which would be 5:00pm.
// Then from 8:00pm, it would start sloping down from 45% all the way back to 15% within 90 minutes, which would be 9:30pm.
//CheckCloud(); (May be used at a later date with cloud/storm effects)
if (hour()>=22 || hour()<8)
ReefAngel.PWM.Set(MoonPhase()); //Moon phase schedule between 10:00pm - 7:00am
ReefAngel.PWM.Expansion(LEDWhiteBlue,int(PWMChannel[LEDWhiteBlue]));
ReefAngel.PWM.Expansion(LEDWhiteBlue1,int(PWMChannel[LEDWhiteBlue1]));
ReefAngel.PWM.Expansion(LEDWhiteBlue2,int(PWMChannel[LEDWhiteBlue2]));
ReefAngel.PWM.Expansion(Mixed LED,int(PWMChannel[Mixed LED]));
//------------------------------------------------- End PWM Expansion Code for Slope ----------------------------------------------
// From Roberto - THANKS ROBERTO!
void CheckCloud()
#define Clouds_Every_5_Days 1
#define Cloud_Chance_per_Day 25
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(20,0)
#define Lightning_Change_per_Cloud 25
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(26);
if ((day()%Clouds_Every_5_Days)!=0) cloudchance=0;
// If we have cloud today
if (cloudchance)
lightningchance=random(36);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
lightningchance=random(54);
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
- JNieuwenhuizen
Yes, entire .pde
// Autogenerated file by RAGen (v1.2.1.158), (03/08/2012 22:54)
#include <avr/pgmspace.h>>
//---------------------------------------------------- PWM Cloud ------------------------------------------------------------------
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
#define Mixed LED 3
#define LEDPWM5 5
byte PWMChannel[]={
0,0,0,0,0,0};
byte MoonPWMValue;
// Globals Needed for Params on Custom Main
byte x,y;
int v;
// Globals Needed for RF Mode on Custom Main
byte vtechmode;
boolean bFeeding=false;
//------------------------------------------------------ Custom Menu Code ---------------------------------------------------------
prog_char menu6_label[] PROGMEM = "Salinity Calibration";
prog_char menu7_label[] PROGMEM = "Vortech Setup";
prog_char menu8_label[] PROGMEM = "Date / Time";
prog_char menu9_label[] PROGMEM = "Version";
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupCalibrateSalinity();
void MenuEntry7()
void MenuEntry8()
ReefAngel.SetupDateTime();
void MenuEntry9()
ReefAngel.DisplayVersion();
//------------------------------------------------------ Grouped Menu Entries ----------------------------------------------------
menu4_label, menu5_label, menu6_label,
menu7_label,menu8_label,menu9_label
//---------------------------------------------------------- Custom Main ----------------------------------------------------------
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Drop Reef ");
// Display T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Sump");
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
// Display the T2 Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Room");
// Display the T2 Temp Value
ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
// Display Vortech MP40wES Mode Header Text
ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
ReefAngel.LCD.DrawText(0,255,40,68,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 31, 78, text, Num8x8);
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox(13, 97, TempRelay);
// Display Expansion Relay Box 1
ReefAngel.LCD.DrawOutletBox(13, 109, TempRelay);
//Draw Date & Time
ReefAngel.LCD.DrawDate(6, 123);
void DrawCustomGraph() // Not Used
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
ReefAngel.SetTemperatureUnit(1);
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit;
//---------------------------------------------------- Ports that are always on ----------------------------------------------------
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Box1_Port8);
//--------------------------------------------------------- RF Module Setup -------------------------------------------------------
ReefAngel.RF.SetMode(Slave_Start,0,0);
If you get a compile error similar to this:
'class ReefAngelClass' has no member named 'RF'
Please make sure that you enabled RF Expansion on your features file.
Open RAGen and make sure you have RF Expansion checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
#define RFEXPANSION
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(128);
InternalMemory.RFDuration_write(10);
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
//------------------------------------------------------ Specific functions -------------------------------------------------------
ReefAngel.Relay.DelayedOn(Port2, 1);
ReefAngel.StandardATO(Port3);
ReefAngel.MoonLights(Port5);
ReefAngel.StandardLights(Box1_Port6);
ReefAngel.StandardLights(Box1_Port7,120);
ReefAngel.MHLights(Box1_Port8);
ReefAngel.StandardHeater(Port6);
ReefAngel.Portal("JNieuwenhuizen");
ReefAngel.Refresh();
0);
0);
//------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//------------------------------------------------ Start Feeding Mode Schedule ----------------------------------------------------
// if the hour is 7pm, minute is 30 and seconds is 0
// start the feeding mode
if ( ((hour() == 17) &&
(minute() == 30) &&
(second() == 0) ) )
vtechmode = InternalMemory.RFMode_read();
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
if (hour() >=8 && hour() <= 22)
if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
bFeeding=false;
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,155,5);
ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
ReefAngel.Timer[4].Start();
vtechmode = 5;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
ReefAngel.RF.UseMemory=true;
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=22 || hour()<8) // Defining "Nightmode" hours for VorTech = between 10 PM and 8 AM
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
ReefAngel.PWM.SetActinic(MoonPhase()); //Moon phase schedule between 10:00pm - 7:00am
ActinicPWMValue=PWMSlope(12,00,19,0,0,90,150,ActinicPWMValue); //Actinic turn on at 7am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
//ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(8,00,22,0,0,90,240,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
cstart*=60;
cend*=60;
Very complex
Try this:
Try this:
#define LEDWhiteBlue 0
#define MixedLED 3
#define LEDPWM5 5
byte PWMChannel[]={
0,0,0,0,0,0};
byte MoonPWMValue;
byte x,y;
int v;
byte vtechmode;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
void MenuEntry9()
//Top Banner
char text[7];
// Display pH Value
//Draw Date & Time
// ReefAngel.RF.SetMode(Slave_Start,0,0);
#define RFEXPANSION
0);
PWMChannel[MixedLED]=PWMSlope(
0);
PWMChannel[LEDWhiteBlue1]=PWMChannel[LEDWhiteBlue];
PWMChannel[LEDWhiteBlue2]=PWMChannel[LEDWhiteBlue];
ReefAngel.PWM.SetChannel(3,PWMChannel[MixedLED]);
if (PWMChannel[LEDWhiteBlue]) MoonPWMValue=0;
//#define Night 9
//#define None 99
(minute() == 30) &&
(second() == 0) ) )
bFeeding=false;
vtechmode = 5;
vtechmode = 9;
void CheckCloud()
could happen.
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
cstart*=60;
cend*=60;
- JNieuwenhuizen
It Works!
Thank You. Now only 1 thing left... I used other code, and then found the one that defines the channels for cloud and lightning.
This is not in the code : I see it has some lines that display, I dont need them.
This worries me a bit - So Channel 0 , 1 , 2 will be used for daylight and atinics. Its all mixed LED's. I think 0 and 2 for clouds, and 1 and 3 for lightning
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
lightningchance=random(100);
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000111
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B111000
- JNieuwenhuizen
Think I figured it out , its simply 0 0 0 0 0 0 , one per channel from right to left
so to use 0 and 2 - B000101
And to use 1 and 3 - B001010
All thats left now is this :
It daws text to the screen, I dont think I have space for it. Or if anyone can give me the spacing for it to be in here somewhere
int x=0;
int x=0;
//Draw Date & Time
Yeah, you got it.
You can move the stuff around.
The function DrawText() has 5 parameters:
1st - Forecolor
2nd - Backcolor
3rd - X position on the screen
4th - Y position on screen
5th - Text to be placed on the screen
The DrawOutletBox() has 3 parameters:
1st - X position on the screen
2nd - Y position on screen
3rd - Relay data to be placed on the screen
You can move stuff around until you get it to fit in your screen
1st - Forecolor
2nd - Backcolor
