Servo ball valve
Ismaclst
Servo ball valve
Post by Ismaclst »
This is a long shot, but does anyone know if they make a servo pvc ball valve? I'm looking to be able to have an adjustable valve controlled by the reef angel. I found some but they are not servo controlled and are either all the way open or closed.
Re: Servo ball valve
I was looking for the same thing a few weeks ago and couldn't find anything.
I also found quite a few of them that were on/off and they were in the range of $400+.
If you do find anything, please let me know.
Ismaclst
Post by Ismaclst »
Yeah, I found out how expensive they can run, unfortunately. I will let you know if I come across anything promising.
Ismaclst
Post by Ismaclst »
Don't think this is quite what we are looking for, but it's a lot cheaper and it gives you a signal if it's fully opened or fully closed.
http://www.aliexpress.com/item/1-1-2-DC ... 43cc5caaa6
Ismaclst
Post by Ismaclst »
Just posting the size I need here so I don't lose it.
http://www.aliexpress.com/item/1-DC12V- ... d6f0b056bc
Probably easier to get a few solenoid valves and use that then finding a good electric ball valve
