Main Relay 1
Expansion Relay 1
Expansion hub
RLD
Buzzer
Controller head unit is PWM.
I can't exactly find clear instructions on how to add the 2nd outlet box. It's plugged into the expansion hub, which is plugged into the main outlet box.
I tried opening it up, I saw the jumpers were set to analog and 1<>2 for the 1-3 jumpers. I changed to pwm, reassembled, can't get any outlets to turn on/off. Set jumper to 2<>3, doesn't work. Take jumper off, doesn't work.
Ideas?
Thanks very much!!
