will not download codes while programming new RA
bmeyer0627
hey! so I'm sure theres a logical explanation but for whatever reason when I go to start uploading the codes on my new RA it says that there is an error and that it cant upload. the download for the drivers was successful and the icon has appeared but I cant upload codes. ideas?
i throw peanuts at old ladies
- cosmith71
Re: will not download codes while programming new RA
PC or Mac?
Make sure you've selected the correct COM port under Tools->Serial Port.
The RA needs to be connected to either the relay box or the USB temp port power cable (it has to have power).
Make sure the programmer cable is plugged in with the black wire all the way to the right.
A screen shot showing the error might be helpful too.
keepLearning
I got errors while the simple code being compiled too. I can roll back to the default code but that is it. I use the wizard to try something like keep the relay outlets on and turn off when in feed mode.
This line below got an error
FeedingModePortsE is not a member of ReefAngel class. I download the reef angel installer from the download link. It looks like i have a mismatched in the library version. Any help is appreciated.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
Do you have the relay expansion module?
If you don't make sure to not select it.
If you do, make sure to assign something to the relay ports of the relay expansion.
keepLearning
I double checked. Rookie mistake.
Thank you for your help.
