Portal not working
Related to the Portal
marcoc
Portal not working
Post by marcoc »
Hi,
I cannot make the portal working. It gives "Unreachable Address". It is probably a port forwarding problem. I have read lots of threads, but I was not able to solve it. Please bear with me, but I am not very expert in this field of router setting. I have a TP-Link Archer D7. I have gone into the Forwarding table and enabled a virtual server (?) as follows:
Service Port-------IP Address------------Internal Port-------Protocol---------Status-------WAN
2000---------------192.168.1.108------------2000-----------TCP or UDP------Enabled-----pppoe_8_35_1_d
Now, when I check the opening of the port, it results opened.
Can anyone help?
Thank you very much.
