ReefAngel external web access [GUIDE]
Would you like to help?
Poiromaniax
Post by Poiromaniax »
Hey All,
Attached is my guide to setting up ReefAngel External web access :)
Enjoy and let me know if it helps
EDIT - Using this guide first should make life a bit easier too! - http://forum.reefangel.com/viewtopic.php?f=14&t=3427
Re: ReefAngel external web access [GUIDE]
Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
Otherwise, nice guide. :)
Also, did you know that http://www.no-ip.com offers the free dynamic service (if you didn't want to pay dyndns)? I personally have accounts with both and they both work just fine for me.
Poiromaniax
binder wrote:Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
cool :)
Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one :( I wish I couldve
Sebyte
Post by Sebyte »
Nice work :D
I will add a link to this from my "where to get started" guide, if that's ok?
Poiromaniax
Sebyte wrote:Nice work :D
With pleasure :)
oscarinw
Post by oscarinw »
Poiromaniax wrote: Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one :( I wish I couldve
Actually if you choose the dyndns from the dropdown menu and then input the host you get from no-ip.com, it works just the same... It stumped me too for a little while and then figured it's the same.
Hope it helps!
Poiromaniax
Hope it helps!
It all depends on your brand of router and the firmware it's on I believe.
As far as I'm aware, you can also get custom firmware to add more dns service providers
Thanks for the info though - hopefully it will help someone out :)
Echo5delta16
Post by Echo5delta16 »
So this reef angel cant be used to access from anywhere unless I BUY a dydns thing?
