Hi Friends, What I need for use one Dosing Pump? Off course- I know, buy one Dosing Pump in the Store but something else? Where I will need connect that?
Thank you a lot.
Dosing Pump
- cosmith71
Re: Dosing Pump
You plug it into an outlet on the relay box. You will need airline tubing as well.
LucianoB
Re: Dosing Pump
Thank you for your answer. So in the relay box I will need use one 110v/12v Converter right? If I dont like use one Converter, what I need, do you know?cosmith71 wrote:You plug it into an outlet on the relay box. You will need airline tubing as well.
Regards
- cosmith71
Re: Dosing Pump
Yes. It comes with the pump.
