portal not working, phone app is
psyrob
My portal page keeps showing data from February, when I reload it it shows todays date for a second then goes back to february. Just before it goes back to February, the Connection Status says "Error - 0" for a brief section.
My iphone app is current and both are pointing to the same IP address and port and I confirmed that my port is open. Any ideas why the portal isn't updating even as my iphone app is?
thanks
thanks
Re: portal not working, phone app is
Can you post what you get when you browse http://ipaddress:2000/r99 ?
psyrob
Here is what came up. Now, when I check the portal from work, it is current. Could it be only happening from my house, like my router changing the IP?
<RA>
<ID>psyrob</ID>
<T1>811</T1>
<T2>784</T2>
<T3>807</T3>
<PH>800</PH>
<R>175</R>
<RON>0</RON>
<ROFF>246</ROFF>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>0</EM>
<EM1>2</EM1>
<REM>0</REM>
<BID>1</BID>
<AF>1</AF>
<SF>0</SF>
<PWMA>91</PWMA>
<PWMD>50</PWMD>
<PWMAO>255</PWMAO>
<PWMDO>255</PWMDO>
<DCM>13</DCM>
<DCS>100</DCS>
<DCD>22</DCD>
<DCT>30</DCT>
</RA>
<RA>
<ID>psyrob</ID>
<T1>811</T1>
<T2>784</T2>
<T3>807</T3>
<PH>800</PH>
<R>175</R>
<RON>0</RON>
<ROFF>246</ROFF>
<ATOLOW>0</ATOLOW>
<EM>0</EM>
<EM1>2</EM1>
<REM>0</REM>
<BID>1</BID>
<AF>1</AF>
<SF>0</SF>
<PWMA>91</PWMA>
<PWMD>50</PWMD>
<PWMAO>255</PWMAO>
<PWMDO>255</PWMDO>
<DCM>13</DCM>
<DCS>100</DCS>
<DCD>22</DCD>
<DCT>30</DCT>
</RA>
psyrob
Ok, there can be two things.
You are using timer 4 or your wifi attachment is not properly configured.
Let's start with the easier. Can you post your code?
psyrob
Sorry for the delay, been busy at work: here is my code, note from my banner that the portal is showing data from February... Does this give any answers?
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port7Bit;
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.SingleATOLow( Port5 );
ReefAngel.StandardFan( Port8 );
ReefAngel.Portal( "psyrob" );
ReefAngel.DDNS( "99.90.0.55:2000" ); // Your DDNS is psyrob-99.90.0.55:2000.myreefangel.com
}/code]- lnevo
Check under Portal Settings in the Portal and make sure you don't have a key setup.
Also your DDNS name. Should just be a name and shouldn't have your IP and Port.
psyrob
do you mean the ddns name should be in my code, and not the IP and Port? As in this line in the code:
should really be
ReefAngel.DDNS("psyrob");//
should really be
more like controller1. Then your DDNS name will be psyrob-controller1.myreefangel.com
But the key is more than likely your current problem.
psyrob
Well, I'm still not able to connect. I redid my code thru the wizard, and this is what it created:
And again, my iphone app works but the portal does not. And I don't have a key set up on the portal. I checked that. I will try and change in the code "psyrob" to "psy-rob-controller1.myreefangel.com" and see if that works.
any other ideas?
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.StandardFan( Port1 );
ReefAngel.DayLights( Port4 );
any other ideas?
psyrob
So I switched my code at the end as follows:
and it didn't work at first , it went to February data, but after refreshing the page a few times, current data popped up. I will keep an eye on it, but thanks for the help
ReefAngel.DDNS( "psyrob-controller1.myreefangel.com" ); // Your DDNS is psyrob-99.90.0.55:2000.myreefangel.com
