problem with relay box?
Meshmez
Post by Meshmez »
I was taking the relay box off my old tank to move to my new tank, and i heard a rattling inside. I was able to get a small piece of something to fall out. I have attached pictures. its a little under 1/4" square. It looks like the casing on an electrical component, a capacitor or something. Is this anything to be worried about?
Meshmez
Re: problem with relay box?
Post by Meshmez »
anyone ?
You should be fine, but if you want it replaced, send it back.
Those are part of the dampening circuit if you use Koralias as wavemakers.
Meshmez
Post by Meshmez »
Thanks for the response Roberto! If i just use it as is, is there any problem/danger?
It will only be a problem if you run Koralias as wavemakers on port 5 or 6.
Meshmez
Post by Meshmez »
I have run them in the past and would like the option to in the future. what will happen if i do? sounds like i should probably send it in...
Your controller may reboot once in a while when you are running a rapid on/off on those ports. That's why only port 5 and 6 are intended to be used as wavemakers when koralias are used. Only those ports have the dampening circuit.
