Relays keep switching to auto
Related to the Portal
PostPosted: Thu Aug 11, 2016 4:22 pm
I have 2 relay outlets that I use for mixing and water change pumps. When I set them to off in the app for some reason they will switch to auto on there own. Is there some sort of timer that will kick them to auto after a certain amount of time? It's only those two that I notice since the rest stay in auto.
PostPosted: Mon Aug 15, 2016 2:31 pm
Well after playing with my coding today I noticed those switches kicked on when the controller was disconnected from wifi. I have been having issues with my wifi lately as well. Is this normal for the relays that are programmed to always on?
PostPosted: Tue Aug 16, 2016 3:33 am
Post your code.
PostPosted: Tue Aug 16, 2016 4:44 pm
Sounds like maybe the box is rebooting? Can you watch the screen next time and see if that's the case?
Return to Portal
