I can connect via the portal, and also by aquarium log (sometimes) but I cannot connect to the RA directly using http://IP:2000/wifi it just brings up a blank page, but IP:2000 brings up: Reef Angel Controller Web Server, also IP:2000/sa works but only sometimes. Should I try and upgrade the firmware on the wifi?
Also on a side note: any EASY way to change the PWM dimming on the fly, like if I want blues at 100% while I work on the tank, but just an override that will revert if I change it back. I was logging into the wifi RA direct, but its kind of a pain.
I can PM my ip if you want to test it.
-Joe
wifi adapter acting strange
Re: wifi adapter acting strange
You can set the pwm overrides to a value 0-100. Anything above cancels the override. Take a look at the thread wifi attachment commands (think its in the portal forum)
Its something like this /pwmao100 to set the actinic channel to 100.
As far as the rest the /wifi relies on external files. Maybe the site is blocked where your testing? Either way I'd say check your port forwarding
tech9
So maybe my files on RA are just corrupt:
Why do I get this also:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM5
< CMD
< GET /r99 HTTP/1.1
< Host: 192.168.88.189:2000
> reboot
** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM5
< CMD
> ftp u
< ftp u
< <4.41>
< FTP connecting to 198.175.253.161
< FTP file=27:...GET /r99 HTTP/1.1
< ....................GET /r99 HTTP/1.1
< UPDATE OK
< FTP OK.
> ftp r wps.img
< HTTP/1.1 400 Bad Request
< Content-Type: text/html
< Date: Wed, 31 Aug 2016 00:56:21 GMT
< Connection: close
< Content-Length: 20
> set u b 57600
> set s p 0
> save
> reboot
< CMD
< GET /r99 HTTP/1.1
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.41>
< UPDATE OK
< FTP OK.
> ftp r wps.img
< Connection: close
You have something trying to connect to the module.
Most likely the client suite.
I would recommend stopping it before you try to perform any update or it will keep interrupting it.
tech9
Actually yes, I just discovered that, i couldn't figure out what was doing that. Still not updating for some reason. I did a factory reset on the wifi module, and re-setup and even tried the TeraTerm "fix" you posted.
But I reloaded the RA to factory, uploaded my wizard code, its working 100%, except the wifi dashboard
It goes to the "Reef Angel Controller Web Server" just fine, but blank page on the /wifi, tried on different computers, my phone, etc. Where are those files stored that it cannot access. Also I am connecting locally when trying this: http://192.168.88.189:2000/wifi It all started after a power outage.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
< DHCP in 2143ms, lease=600s
< IF=UP
< DHCP=ON
< IP=192.168.88.189:2000
< NM=255.255.255.0
< GW=192.168.88.1
< Listen on 2000
> ftp u
< ftp u
< <4.41>
< FTP file=25:................................................................
< UPDATE OK
< FTP OK.
> ftp r wps.img
< ftp r wps.img
< <4.41>
< 550 wps.img: The system cannot find the file specified.
< FTP ERR
Removing connection to COM5-
/wifi was not working for anybody.
The reefangel.com server had missing files after I moved hosting provider.
It's fixed now and you should be able to get /wifi again.
