I am trying to use the portal and app. I have checked my code and it looks like I have everything in there that is needed. When I access the portal it works but the dashboard is incorrect. It is only showing one relay box it should show three. When I first enter portal it is always on a date in Sept 2013 as last data, but I have looked at it since 2013 . If I cycle a relay on the dashboard it will then refresh and show correct data? This only happens on my computer not my Iphone if I access the portal from my phone It is correct dashboard and data is refreshed.
Second issue is when I add the ipaddress that the portal is using to the App it does not work?
Am I correct in using that ip? Also I do have comcast:
Wifi setup went well no issues. green light flashes every sec. no blue light flashing,good right?
I also Went into comcast router and turned on port forwarding :2000 for the ip of the wifi attachment.
Any help on this would be great.Thank you
Here is my Code:
ReefAngel.AddPARExpansion(); // PAR Expanion Module
ReefAngel.FeedingModePortsE[0] = Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port5Bit;
ReefAngel.DDNS("tank" );
ReefAngel.Relay.On( Box3_Port1 );
ReefAngel.Relay.On( Box3_Port2 );
ReefAngel.Relay.On( Box3_Port3 );
ReefAngel.Relay.On( Box3_Port4 );
ReefAngel.Relay.On( Box3_Port5 );
ReefAngel.Relay.On( Box3_Port6 );
ReefAngel.Relay.On( Box3_Port7 );
ReefAngel.Relay.On( Box3_Port8 );
ReefAngel.StandardLights( Port2,10,0,19,30 );
ReefAngel.StandardFan(Box1_Port7,806,786);
ReefAngel.StandardFan2(Box1_Port8,900,856);
ReefAngel.StandardLights( Port3,10,0,19,30 );
ReefAngel.StandardLights( Port4,10,0,19,30 );
ReefAngel.SingleATO( true,Port8,60,0 );
// ReefAngel.StandardHeater( Box1_Port5,627,810 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.PWM.SetChannel( 2, MoonPhase() );
ReefAngel.PWM.SetChannel( 3, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(10,0,19,30,15,100,60,15) );
ReefAngel.Portal( "bmhair03" );
Portal and U-app fine tuning help
Re: Portal and U-app fine tuning help
Update..
OK I have the portal running fine dashboard correct etc .But still cant get app to work. Any advice there?Thanks
Started to just click stuff in App. Now it's working. Did the same as portal cycled a relay and it started working perfectly.
So thank anyway but I'm ok. For now !
