Portal email alerts
ucez
Portal email alerts
I've been trying to get this to work for a while, but can't seem to figure it out.
Right now, I've got alerts setup if relay 7 is either on (=1) or off (=0). When I turn the relay on/off, no alerts. The relay activity chart is correct, just no alerts.
What am I missing? I've tried different email addresses. Do I need something in the code?
Re: Portal email alerts
Controller only send data to portal every 5 minutes. Are you waiting at least 5 minutes?
The log shows that email alerts were sent yesterday for your main relay port 2.
Did you not get those?
ucez
Nope. I checked spam filter, nothing there, but added another email account just in case. I tried this before and it didn't work, but will let you know if something happens.
ucez
Still nothing.
Sent from my LG-V410 using Tapatalk
I think it is a server issue.
I made a small change. Let me know if you get them now.
ucez
All my portal alerts have disappeared. I tried to add them back, but not showing up...
Should be working now.
You can't use < or > signs in the item name.
tech9
How do you setup email alerts in the portal? Or are you talking about the phone app?
Also, my web chart is only showing things from 5 days ago. And I when I view others it does the same, server issue?
- Contact:
he's probably talking about the portal. it's towards the bottom and you can enable it. i have a separate android app that allows you to manage your portal notifications for ease of use (that's the only thing it does).
ucez
So, the same problem seems to have reemerged... I can connect to controller via tablet (ip address), but the portal isn't getting any data. Seems to have stopped a couple of weeks ago. No changes to the code.
Any ideas?
Any ideas?
ucez
NVM - Unplugged the wifi cable and plugged it back in, now seems to be OK.
