Help Getting started again.
I switched over from a PC to a MAC and I think I have the software and the Bluetooth adapter setup properly, but something has changed since my last version of the library 1.1.1 (1/04/16 I believe) to the version that is on the MAC Download on the website (I'm not sure what version it is).
When I try to upload it I get the following error for this line of code...
static time_t LastATO=millis();    // For de-bounced ATO
'time_t' does not name a type
And this is what I get in the Verbose read out...
Watchdog Timer
Version Menu
java.io.FileNotFoundException: /Users/Steves-iMac/Documents/Arduino/Code/update/feature.txt (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:120)
at java.io.FileInputStream.<init>(FileInputStream.java:79)
at java.io.FileReader.<init>(FileReader.java:41)
at processing.app.Sketch.ProcessFeature(Sketch.java:1373)
at processing.app.Sketch.build(Sketch.java:1766)
at processing.app.Sketch.exportApplet(Sketch.java:1797)
at processing.app.Sketch.exportApplet(Sketch.java:1783)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2357)
at java.lang.Thread.run(Thread.java:695)
Standard Menu
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1705)
at java.io.File.createTempFile0(File.java:1726)
at java.io.File.createTempFile(File.java:1803)
at processing.app.Base.saveFile(Base.java:2189)
at processing.app.Sketch.ProcessFeature(Sketch.java:1456)
/Applications/Reef_Angel.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -I/Applications/Reef_Angel.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Applications/Reef_Angel.app/Contents/Resources/Java/hardware/arduino/variants/standard -I/Applications/Reef_Angel.app/Contents/Resources/Java/libraries/Wire -I/Applications/Reef_Angel.app/Contents/Resources/Java/libraries/SoftwareSerial /var/folders/vj/m9jly2mx411fbfrc8qdg1z2c0000gn/T/build4342936369941451460.tmp/Steves_Backup.cpp -o /var/folders/vj/m9jly2mx411fbfrc8qdg1z2c0000gn/T/build4342936369941451460.tmp/Steves_Backup.cpp.o
Steves_Backup.cpp:1:32: warning: ReefAngel_Features.h: No such file or directory
Steves_Backup.cpp:2:21: warning: Globals.h: No such file or directory
Steves_Backup.cpp:3:21: warning: RA_Wifi.h: No such file or directory
Steves_Backup.cpp:5:21: warning: OneWire.h: No such file or directory
Steves_Backup.cpp:6:18: warning: Time.h: No such file or directory
Steves_Backup.cpp:7:23: warning: DS1307RTC.h: No such file or directory
Steves_Backup.cpp:8:28: warning: InternalEEPROM.h: No such file or directory
Steves_Backup.cpp:9:25: warning: RA_NokiaLCD.h: No such file or directory
Steves_Backup.cpp:10:20: warning: RA_ATO.h: No such file or directory
Steves_Backup.cpp:11:25: warning: RA_Joystick.h: No such file or directory
Steves_Backup.cpp:12:17: warning: LED.h: No such file or directory
Steves_Backup.cpp:13:27: warning: RA_TempSensor.h: No such file or directory
Steves_Backup.cpp:14:19: warning: Relay.h: No such file or directory
Steves_Backup.cpp:15:20: warning: RA_PWM.h: No such file or directory
Steves_Backup.cpp:16:19: warning: Timer.h: No such file or directory
Steves_Backup.cpp:17:20: warning: Memory.h: No such file or directory
Steves_Backup.cpp:19:23: warning: RA_Colors.h: No such file or directory
Steves_Backup.cpp:20:29: warning: RA_CustomColors.h: No such file or directory
Steves_Backup.cpp:21:22: warning: Salinity.h: No such file or directory
Steves_Backup.cpp:22:16: warning: RF.h: No such file or directory
Steves_Backup.cpp:23:16: warning: IO.h: No such file or directory
Steves_Backup.cpp:24:17: warning: ORP.h: No such file or directory
Steves_Backup.cpp:25:16: warning: AI.h: No such file or directory
Steves_Backup.cpp:26:16: warning: PH.h: No such file or directory
Steves_Backup.cpp:27:24: warning: WaterLevel.h: No such file or directory
Steves_Backup.cpp:28:22: warning: Humidity.h: No such file or directory
Steves_Backup.cpp:29:20: warning: DCPump.h: No such file or directory
Steves_Backup.cpp:30:23: warning: ReefAngel.h: No such file or directory
Steves_Backup.cpp:43:1: warning: "Unused" redefined
Steves_Backup.cpp:38:1: warning: this is the location of the previous definition
Steves_Backup.cpp:45:1: warning: "Unused" redefined
Steves_Backup.cpp:43:1: warning: this is the location of the previous definition
Steves_Backup.cpp:46:1: warning: "Unused" redefined
Steves_Backup.cpp:45:1: warning: this is the location of the previous definition
Steves_Backup.cpp:47:1: warning: "Unused" redefined
Steves_Backup.cpp:46:1: warning: this is the location of the previous definition
Steves_Backup:57: error: 'time_t' does not name a type
Steves_Backup.cpp: In function 'void setup()':
Steves_Backup:65: error: 'ReefAngel' was not declared in this scope
Steves_Backup:69: error: 'Port4Bit' was not declared in this scope
Steves_Backup:70: error: 'Port1Bit' was not declared in this scope
Steves_Backup:72: error: 'Port2Bit' was not declared in this scope
Steves_Backup:76: error: 'T1_PROBE' was not declared in this scope
Steves_Backup:79: error: 'InternalMemory' was not declared in this scope
Steves_Backup:93: error: 'Sync' was not declared in this scope
Steves_Backup:99: error: 'Box1_Port8' was not declared in this scope
Steves_Backup.cpp: In function 'void loop()':
Steves_Backup:109: error: 'ReefAngel' was not declared in this scope
Steves_Backup:113: error: 'PWMSlope' was not declared in this scope
Steves_Backup:125: error: 'hour' was not declared in this scope
Steves_Backup:128: error: 'MoonPhase' was not declared in this scope
Steves_Backup:134: error: 'Box1_Port7' was not declared in this scope
Steves_Backup:135: error: 'weekday' was not declared in this scope
Steves_Backup:135: error: 'dowMonday' was not declared in this scope
Steves_Backup:135: error: 'hour' was not declared in this scope
Steves_Backup:135: error: 'minute' was not declared in this scope
Steves_Backup:138: error: 'weekday' was not declared in this scope
Steves_Backup:138: error: 'dowWednesday' was not declared in this scope
Steves_Backup:138: error: 'hour' was not declared in this scope
Steves_Backup:138: error: 'minute' was not declared in this scope
Steves_Backup:141: error: 'weekday' was not declared in this scope
Steves_Backup:141: error: 'dowFriday' was not declared in this scope
Steves_Backup:141: error: 'hour' was not declared in this scope
Steves_Backup:141: error: 'minute' was not declared in this scope
Steves_Backup:144: error: 'Box1_Port6' was not declared in this scope
Steves_Backup:145: error: 'weekday' was not declared in this scope
Steves_Backup:145: error: 'dowFriday' was not declared in this scope
Steves_Backup:145: error: 'hour' was not declared in this scope
Steves_Backup:145: error: 'minute' was not declared in this scope
Steves_Backup:156: error: 'now' was not declared in this scope
Steves_Backup:160: error: 'now' was not declared in this scope
Steves_Backup:165: error: 'now' was not declared in this scope
Steves_Backup:165: error: 'SECS_PER_DAY' was not declared in this scope
Steves_Backup:170: error: 'FEEDING_MODE' was not declared in this scope
Steves_Backup:173: error: 'now' was not declared in this scope
Steves_Backup:176: error: 'now' was not declared in this scope
Steves_Backup:178: error: 'Box1_Port2' was not declared in this scope
Steves_Backup:182: error: 'Box1_Port2' was not declared in this scope
Steves_Backup:198: error: 'now' was not declared in this scope
Steves_Backup:206: error: 'time_t' does not name a type
Steves_Backup:207: error: 'WATERCHANGE_MODE' was not declared in this scope
Steves_Backup:207: error: 'wcTimer' was not declared in this scope
Steves_Backup:210: error: 'wcTimer' was not declared in this scope
Steves_Backup:241: error: 'ReefCrest' was not declared in this scope
Steves_Backup:241: error: 'Gyre' was not declared in this scope
Steves_Backup:241: error: 'Lagoon' was not declared in this scope
Steves_Backup:241: error: 'Constant' was not declared in this scope
Steves_Backup:241: error: 'TidalSwell' was not declared in this scope
Steves_Backup:241: error: 'ShortPulse' was not declared in this scope
Steves_Backup:241: error: 'LongPulse' was not declared in this scope
Steves_Backup:241: error: 'Else' was not declared in this scope
Steves_Backup:243: error: 'SECS_PER_DAY' was not declared in this scope
Steves_Backup:250: error: 'FEEDING_MODE' was not declared in this scope
Steves_Backup:255: error: 'InternalMemory' was not declared in this scope
Steves_Backup:256: error: 'NutrientTransport' was not declared in this scope
Steves_Backup:257: error: 'SECS_PER_DAY' was not declared in this scope
Steves_Backup:260: error: 'InternalMemory' was not declared in this scope
Steves_Backup:263: error: 'InternalMemory' was not declared in this scope
Steves_Backup.cpp:156: warning: unused variable 'Kalk_Mixing'
Steves_Backup.cpp: In function 'void DrawCustomMain()':
Steves_Backup:289: error: 'ReefAngel' was not declared in this scope
Steves_Backup:291: error: 'pingSerial' was not declared in this scope
Steves_Backup:294: error: 'COLOR_DARKGOLDENROD' was not declared in this scope
Steves_Backup:294: error: 'DefaultBGColor' was not declared in this scope
Steves_Backup:301: error: 'ConvertNumToString' was not declared in this scope
Steves_Backup:303: error: 'DefaultFGColor' was not declared in this scope
Steves_Backup.cpp:288: warning: unused variable 'x'
Steves_Backup.cpp:288: warning: unused variable 'y'
Thanks for the help again.
It's been so long since I have done anything with it.
My current code can be found here http://forum.reefangel.com/viewtopic.php?f=11&t=3873
and at the link in my signature.
Re: Help Getting started again.
Make sure to copy the ReefAngel folder from the download folder into your Documents folder.
It is.
I re-put the Arduino folder into the Documents folder and I'm still receiving the same messages.
I noticed that the default folder for the sketch's in the update folder so I tried moving my sketch over to there and still received the same errors.
I even tried putting the code in the main Arduino folder.
All attempts gave me the same error messages when trying to compile and upload the code.
Any help is appreciated.
Can you check in Preferences where its pointing? What version of the IDE are you using? I need to update to the new one, could be why it's failing..
It is pointing to /Users/Steves-iMac/Documents/Arduino/Code but I have tried /Users/Steves-iMac/Documents/Arduino/update and just /Users/Steves-iMac/Documents/Arduino.
I'm not sure what you mean by what version of the IDE.
I've been away a while and forgot a lot.
The library code?
I don't know how to determine that.
Whatever is part of the download on the website.
It should just be Arduino
I did try just Arduino with the sketch out in the Arduino folder and still the same results.
If you click on Arduino and go to About Arduino it will tell you the version.... just curious if it's the old or new version... I haven't tried upgrading yet.. a bit nervous :)
The version on the site is 1.1.3. I'm going to try and upgrade to this over the weekend.
Roberto is there a permlink to the older version? I'd send him the one I have but I can't find the archive anywhere :(
The MAC version seems to be 1.0.1.
Yeah, the old version is the one in the download page of the website. It is the 1.0.1 IDE with 1.1.3 main branch of libraries.
It appears you got the correct IDE, just mismatched settings.
The sketchbook location should be /Users/Steves-iMac/Documents/Arduino in your case.
After you change it, you must quit Arduino and open it again though. If everything is correct, next time you open Arduino, when you click the open button, you should see the RA_Preloaded and the other codes in the drop down list.
Ok. That seems to be better.
I'm not getting the following error...
I'm getting a very vague "Error Compiling".
There is no line # or anything else.
The last line in the verbose readout is...
/Users/Steves-iMac/Documents/Arduino/libraries/Globals/Globals.h:366: warning: 'RANetStatus' defined but not used
Warnings are safe to ignore. If you don't want to see them, just suppress them. For some reason, the Mac version shows suppressed but you actually need to force it to show and then suppress or it will never suppress. Bug in the IDE, I guess.
Go to File->Preferences and select All and click Ok. Then go back and select none again and click ok.
That will suppress the warnings.
If it is complaining about time_t, you can use unsigned long instead, which is actually better.
There is no preferences under file.
It's under Arduino and there is nothing like you are talking about in those preferences.
This is that pane...
The file section has the following options...
I don't care about the warning as long as it will compile and upload properly, but it won't' do that.
I'm still getting that very vague "Error Compiling".
and it just stops.
It doesn't upload at all.
It happens on the Bluetooth or USB-TTY port connections.
Try downgrading the libraries to the last production version would be my suggestion.
Where do I find those again?
One thing I notice is that your sketchbook is pointing to the wrong folder.
Try deleting the code folder in the path.
I have tried that too.
Can you post the entire error log?
I can't.
It is too large...
Your message contains 137874 characters. The maximum number of allowed characters is 100000.
Save in a text file and attach
The sketch is in /Users/Steves-iMac/Documents/Arduino and the only other error besides the attached is the "error compiling" in the orange bar between the sketch and the error log.
Steves Backip Sketch error log..rtf
(100.92 KiB) Downloaded 637 times
Do you have RA Plus selected as board?
In the log you sent it says this "-mmcu=atmega328p ", which is the wrong chip. Standard RA used 328, but RA+ uses 2560.
Can you also post your code?
That did it.
I was stupid enough to follow the instructions for setting up the software for the MAC which said to set the controller to Reef Angel Controller w/ optiboot.
It's working fine now and the BlueTooth connection worked fine 1st shot.
sweet!
Yep.
Stupid mistake on my part.
Thanks for your help Lnevo and Rimai.
Sorry about the wasted time.☹
Sent from my SM-G928P using Tapatalk
