'Lo all
Can anyone advise if the Android APP can be used to check 2 different portal usernames? I have 2 RA's at home controlling different tanks.
I already set different local statics IP addresses, set a different port on one of the RAs, and adjusted my firewall. Everything works when I log on with either user name on the web portal. I would like to use my phone app for both though.
Any suggestions are appreciated.
Android APP to check 2 profiles?
Smotz
- Contact:
Re: Android APP to check 2 profiles?
No. the android app cannot currently do this. I believe the universal app can and I believe it is also available on android as well.
Smotz
Unfortunately, the 'Portal Username' is specified globally in settings not in each profile.
Smotz
I have wifi security enabled so the universal app doesn't work for me.binder wrote:No. the android app cannot currently do this. I believe the universal app can and I believe it is also available on android as well.
- Contact:
I have started working on multiple profiles but stopped last year due to my life getting busy. I don't have a time frame either.
Smotz
Understood. All you do is very appreciated.binder wrote:I have started working on multiple profiles but stopped last year due to my life getting busy. I don't have a time frame either.
