Client Suite 3.0
89delta
Re: Client Suite 3.0
Post by 89delta »
Will we see a 3.1 with the addition of a DC Pump tab and additions of everything new.
89delta wrote:Will we see a 3.1 with the addition of a DC Pump tab and additions of everything new.
probably not unless dave creates it. he hasn't been around much for a while, so it's doubtful but you never know. I can ask him and see what he says though.
Sent from my Nexus 7
89delta
Post by 89delta »
Thank Curt.
Sent from my Samsung Galaxy Note 3
i talked to dave yesterday and he is uncertain about creating a 3.1 version. he honestly didn't think many people were still using it. he has been out of the loop for a while and he actually took down his fish tank. he told me that he was going to grab the latest libraries and look around the forum and try to get caught up on all the new stuff and changes. he was also going to mess around with my test controller too.
so, who knows what will end up coming from this. just thought i would pass the info along.
I think the only reason people aren't using it is because it hasn't been kept up to date.
89delta
Post by 89delta »
I use it on my media PC and let it run in the background. I actually enjoy the graphing feature of it, being able to see any changes during the day or week while gone for work. But its good to hear Curt.
ok, good info.
i will see if i can push him to update it more....gotta move carefully with him. :-)
89delta
Post by 89delta »
Am in no rush. Am sure we all have been using our phones and tablets for the most part. But an apdate maybe every year or two would be good as well.JMHO But love everything else you all have done so far to bring the RA to this point.
dmolton
Post by dmolton »
Sorry there hasn't been any activity on this project. Like Curt mentioned, my tank has been broken down for awhile now and I didn't think there was much interest anymore. Seeing as there is at least a little bit I can certainly try to push out another update for you guys.
After hearing from Curt yesterday I began piecing together the old development environment to try and get back to where I was. Unfortunately, I think i lost the installer project which as far as this project is concerned, was always one of the biggest obstacles for me. I'll keep looking.
I've only quickly scanned this thread but it seems for sure we're looking for DC Pump support on the main tab or as another tab. I'll need to do a little research on the board and see what kind of capabilities we have with the pump. Also looks like the ini file needs to be updated to support the latest libraries. I'll see if i can find any glaring bugs. Anything else?
I think short-term I'm going to dump all the source code for the project on github in case others want to maintain/branch for a new application. The client user interface has some dependencies on old registered third party controls so its not super friendly for other developers to pick it up and run with it right away.
Long-term I'd like to start a new open source project on github to create a new desktop app to modernize the look and feel while using up-to-date tools and technologies.
89delta
Post by 89delta »
That would be awesome Dave. I'd certainly get a copy from github to see how the code structure works for the program...if not too hard I'd be willing to give it a shot.
woohoo....and the silent man speaks. :-)
see, the interest is there and people are willing to help.
Kungpaoshizi
Post by Kungpaoshizi »
Just fired it up, first issue was the scan didn't detect it in the internal address space.. Might be router settings, lmk if you need more info.
Nice slick setup so far :)
madweazl
Post by madweazl »
I just recently got the RA setup and have been using the client for the past few days. I was curious if the issue in the attachment is related to something I've inadvertently done or just something with the client. If I did it, any idea how to reverse what I've done LOL? The issue is that I have a few lines of the same temp (e.g. two lines of 80°, two lines of 79° etc.). I end up with the same issue on the pH plots as well. If I open and close the app, occasionally I'll get something a little different. I've restarted the computer, stop/started the services etc. but nothing seems to correct it.
silkjc
Post by silkjc »
Just posting to say I really love this application and find it much quicker to use than the portal. I hope development can continue!
GermanDude
Post by GermanDude »
+1
I use this application a lot since I bought my RA+.
-James-
troylong45
Post by troylong45 »
How does this work. Is it connected via ttl/usb to windows 10? I want to get a windows 2 in 1 or a full windows tablet and connect to it will this work?
madweazl
Post by madweazl »
troylong45 wrote:How does this work. Is it connected via ttl/usb to windows 10? I want to get a windows 2 in 1 or a full windows tablet and connect to it will this work?
I have it connected to my desktop (works on Windows 7 and 10) via USB/TTL. In the Settings, Notifications tab, you must check the "send parameters to Reef Angel Portal for online viewing." The SMS and email feature is very handy as well.
Irieivan
Post by Irieivan »
I want to see my water level on the client. Searched here and found this:
Where do I upload this?
In the code?
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port7Bit;
ReefAngel.PHControl( Port2,818,820 );
ReefAngel.StandardLights( Port4,11,0,21,30 );
ReefAngel.Relay.DelayedOn( Port5,1 );
ReefAngel.WaterLevelATO( Port6,120,42,44 );
ReefAngel.StandardHeater( Port7,255,265 );
ReefAngel.Relay.DelayedOn( Box1_Port5,1 );
I don't see any option in the client settings to view water level expansion, just float switches.
Apologies if a stupid question, but am totally new to this
The client is no longer being developer. It still works but I believe the water level sensor came after the client's last release. There is nothing to add to your code for the chart I posted.
89delta
Post by 89delta »
Anyone else having issues with the checkbox for send parameters to Reef Angel Portal for online viewing? I keep trying to click it but nothing happens.
