Reefology's code
Re: Reefology's code
What do you want to do with them...if you want to speed one up or slow one down? Which is currently sync/antisync?
Reefology
Yup, that's what I want. So do I remove the offset then? Leave it at 100? Or change it to some other figure?
I gave you two choices...you answered yup. If you want to speed up the antisync channel then make it 125 for a 25% increase. Or make it 75 for a 25% decrease on the one set to antisync
Reefology
thanks for the info Lee
i answered "yup" because i'd like to know how to manipulate the fields/data going forward, don't just want to rely on you guys to write code for me (though at times i need you to and certainly do appreciate it). sorry for the confusion
Reefology
Hi all,
How do I figure out why I can't upload a sketch when it complies just fine?
This is the error message I'm getting:
Same message I get when try to upload without cable. Can it be a cable issue? It seemed to work yesterday to upload wifitestcode? Sort of...
Make sure you are connecting the cable correctly on RA. It should be all the way to the right and you should have 2 pins unconnected on the left.
Reefology
Hi Roberto,
Yes thanks, I've uploaded sketches many times so it's definitely not that. Any other ideas?
Reefology
// DC pumps
// To run this code must choose Custom in portal
static int rmode;
byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3000) {
// Continue NutrientTranspot Mode for 45 minutes
ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Gyre;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
Reefology
// DC pumps
static int rmode;
changeMode=false;
} else {
Reefology
// DC pumps
static int rmode;
changeMode=false;
} else {
Reefology
not sure which screen you're referring to but in the portal, the internal memory keeps getting reset to 0's for both speed and duration? currently the mode alternates but it was set up in custom??
The RA screen. Move the joystick to the right or left.
Or are you using a custom screen?
Reefology
it says normal mode. what is that? don't see it listed in the portal as a mode.
Normal?
Are you sure you are in the RF screen?
Can you send a picture?
Reefology
Reefology
lol, I just logged in to tell you i figured it out...had the actinic channel set to None and of course thought I had the pump wired to daylights :p
thanks Roberto
thanks Roberto
Reefology
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights( Port5, 19,0,7,0);
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.DosingPumpRepeat3( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync; // WP40
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
ReefAngel.DCPump.AntiSyncOffset=125;
// DC pumps
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
changeMode=false;
// Continue NutrientTranspot Mode for 30 minutes after feeding
if (now()-feeding<1800) {
ReefAngel.DCPump.Speed=80;
} else if (now()%SECS_PER_DAY>25200 && now()%SECS_PER_DAY<=68400) { // 7am to 7pm
} else {
thanks
ReefAngel.StandardLights( Port5 );
ReefAngel.DCPump.LowATOChannel = Sync; // WP40 & SW 8
ReefAngel.DCPump.HighATOChannel = None; //
// DC pumps....................................
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
if (now()%1800==0 || changeMode==true) // Change every 30 mins (1800seconds) or controller reboot
changeMode=false;
ReefAngel.DCPump.Mode=ReefCrest;
// Night/Quiet mode
else if (hour()>=2 && hour()<8 ) // 2am to 8am
ReefAngel.DCPump.SetMode( Sine,35,10 );
else if (hour()>=15 && hour()<19) // 3pm and 7pm
ReefAngel.DCPump.SetMode( LongPulse,30,1 );
//Storm mode
else if (hour()>=1 && hour()<2) // 1am and 2am
ReefAngel.DCPump.SetMode( Else,80,15 );
else if (hour()>=11 && hour()<12) // 11am and 12pm
ReefAngel.DCPump.SetMode( LongPulse,95,2 );
else if (hour()>=21 && hour()<22) // 9pm and 10pm
ReefAngel.DCPump.SetMode( ReefCrest,85,15 );
} else {
Reefology
InternalMemory.LCDID_write(255); //this line was added when i got a replacement RA+ board
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.DelayedOn(Port5 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
ReefAngel.DCPump.AntiSyncOffset = 125;
// Wavemaker
if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
ReefAngel.Relay.Off(Port6);
ReefAngel.WavemakerRandom( Port6, 30, 300 ); // random between 30 and 300 seconds
static int rmode;
changeMode=false;
ReefAngel.DCPump.Speed=75;
// Night/Quiet mode
ReefAngel.DCPump.SetMode( Gyre,40,10 );
ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
//Storm mode
ReefAngel.DCPump.SetMode( Else,70,15 );
ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
ReefAngel.DCPump.SetMode( ShortPulse,85,30 );
} else {
Reefology
Hoping someone can help with this. I'd like to add Seasonal changes to my code but can't get it to compile.
where exactly do I input this?
void SeasonalTemps ()
static int heatArray[][2] = { {782,786},// default in case of error in month=0 (June)
{760,764},//January (winter)
{764,768},//February (winter)
{765,769},//March (early spring)
{769,773},//April (spring)
{775,779},//May (spring)
{782,786},//June (early summer)
{789,793},//July (summer)
{796,800},//August (summer)
{786,790},//September (early fall)
{777,781},//October (fall)
{770,774},//November (fall)
{765,769} };//December (early winter)
ReefAngel.StandardHeater( Port3,heatArray[month()][0],heatArray[month()][1]);
}//end seasonalTemps
- Contact:
you have to simply copy the entire function and paste it into your INO file, most likely at the end of it. well after the last curly brace of the loop.
Reefology
static int heatArray[][2] = { {780,784},// default in case of error in month=0 (May)
{764,768},//January (winter)
{768,772},//February (winter)
{772,776},//March (early spring)
{776,780},//April (spring)
{780,784},//May (spring)
{784,788},//June (early summer)
{788,792},//July (summer)
{784,788},//August (summer)
{780,784},//September (early fall)
{776,780},//October (fall)
{772,776},//November (fall)
{768,772} };//December (early winter)
ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
SeasonalTemps ();
ReefAngel.ActinicLights( Port2 ); //ATS pump
ReefAngel.DayLights( Port3 ); //ATS light
ReefAngel.StandardLights( Port4, 23,0,7,0); //Skimmer 11pm-7am
ReefAngel.DCPump.LowATOChannel = Sync; // SW 8
//ReefAngel.DCPump.AntiSyncOffset = 125; // % (0-255) of main pump (Sync)
// koralia 1150
// if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
// else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
// DC pumps
static int rmode;
changeMode=false;
ReefAngel.DCPump.Mode=Else;
} else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11pm to 11am
ReefAngel.DCPump.Speed=40;
} else {
Reefology
Hoping someone from this great community can help as I'm not sure how to implement this. I'm looking to turn my kalk stirrer (port 7) off between 5pm and 11pm.
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 );
if the statement above is correct, where should I input it into my code?
Reefology
Hi Roberto,
so like this?
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off(Port7 );
so like this?
Reefology
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port2 );
SeasonalTemps();
ReefAngel.ActinicLights( Port3 ); //Skimmer
ReefAngel.DayLights( Port4 ); //ATS light
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 ); //kalk dosing off 5pm-11pm
// koralia 1150
// DC pumps
static int rmode;
changeMode=false;
} else {
Reefology
