Float switchs not working.
jjdezek
Recently my float switches aren't kicking my ato pump on when it gets low, having to do it manually through the app. Is it normal for them to stop working could it be the connection in the motherboard? I just ordered new switches in hopes that it fixes the issue. I know I pushed down on the connection port and it kicked on but would turn off until I let go (released pressure).
jjdezek
Re: Float switchs not working.
Got the new float switches and it's still not working. When I move the floats it toggles shows the sensors are working on my screen, it's just not kicking the pump on for some reason.
jjdezek
Disregard I had that relay turned off on my app so it wasn't allowing it to kick on. Amazing how it works when you flip that switch to auto.
