troylong45 ino
troylong45
troylong45 ino
Post by troylong45 »
12/11/2016---updated with fuge light on duing wc and feed mode
11/26/2016---updated to run on the New IDE v1.6.8
This code is mostly from lnevo ino i started with it and removed what i didnt need and added somethings i needed that i came up with and lots that lnevo helped
big thanks to lnevo
  1. need to
  2. *storm causing dimming going to 0 then returning need to stop storm dimming below 2%
    add 2nd relay box +code
    add module expansion +code
  • code running
    reef angel plus
    relay box
    6ch dimming expansion
    wifi module
    ph
    temp
    ato
    skimmer level shut off
    1 return pump
    1 heater
    1 fuge light
    1 Media pump
    2 sb reeflight led boxs
    1 ato pump
    1 skimmer
    1 skimmate collector with float wired in parral with float to shut off if sump water level gets to high
    1 ato float wired in parrel with backup float
  • Float ports
    Low level port ATO
    High level port Skimmer
  • Dimming Ports
    Actinic Moon Left
    Daylight Moon Right
    0, White Left
    1, Blue Left
    2, White Right
    3, Blue Right
    4, DC pump Left
    5, DC pump Right
  • Relay ports
    Return 1
    Heater 2
    Refugium 3
    MediaPump 4
    WhiteLeft 5
    BlueLeft 6
    Autotopoff 7
    Skimmer 8
  • Added features
    SetSun Setup Sun rise/set lighting
    AcclimateLED Apply acclimation dimming
    SetMoon Setup Moon rise/set lighting
    FillInMoon Fill in 5% to 0% gap in main LEDs
    LEDPresets Set preset light levels
    CheckCloud Check for cloud and lightning.
    UpdateLED Set Lights on and off in sync with dimming
    SetTide Set High/Low tide properties
    SetDCPump Set dcpump modes
    #include <SunLocation.h>
    #include <Tide.h>
    #include <Moon.h>
    #include <WiFiAlert.h>
        // Won't compile without this...
        // ReefAngel.DCPump.UseMemory=true;
        // Custom menus
        #include <avr/pgmspace.h>
        const char menu1_label[] PROGMEM = "Feeding Mode";
        const char menu2_label[] PROGMEM = "Water Change";
        const char menu3_label[] PROGMEM = "ATO Clear";
        const char menu4_label[] PROGMEM = "DC Pump Mode";
        const char menu5_label[] PROGMEM = "Overheat Clear";
        const char menu6_label[] PROGMEM = "PH Calibration";
        const char menu7_label[] PROGMEM = "Date / Time";
        const char menu8_label[] PROGMEM = "Refugium Light";
        PROGMEM const char * const menu_items[] = {
        menu4_label, menu5_label, menu6_label, menu7_label, menu8_label
        // Define Custom Memory Locations
        #define Mem_B_MoonOffset          100
        #define Mem_B_AtoHourInterval     101
        #define Mem_I_Latitude            108
        #define Mem_I_Longitude           110
        #define Mem_B_AcclRiseOffset      112
        #define Mem_B_AcclSetOffset       113
        #define Mem_B_AcclDay             114
        #define Mem_B_TideMin             117
        #define Mem_B_TideMax             118
        #define Mem_B_PumpOffset          119
        #define Mem_B_FeedingDCPump       120
        #define Mem_B_NightDCPump         121
        #define Mem_B_NightSpeed          122
        #define Mem_B_NightDuration       123
        #define Mem_B_NTMSpeed            124
        #define Mem_B_NTMDuration         125
        #define Mem_B_NTMDelay            126
        #define Mem_B_NTMTime             127
        #define Mem_B_TideMode            143
        #define Mem_B_CloudsEveryXDays    149
        #define Mem_B_CloudChancePerDay   150
        #define Mem_B_MinCloudDuration    151
        #define Mem_B_MaxCloudDuration    152
        #define Mem_B_MinCloudsPerDay     153
        #define Mem_B_MaxCloudsPerDay     154
        #define Mem_B_StartCloudAfterHour 155
        #define Mem_B_StartCloudAfterMin  156
        #define Mem_B_EndCloudBeforeHour  157
        #define Mem_B_EndCloudBeforeMin   158
        #define Mem_B_LightningChance     159
        #define Mem_B_LightMode           160
        #define Mem_B_LightOffset         161
        #define Mem_I_RiseOffset          162
        #define Mem_I_SetOffset           164
        #define Mem_B_AcclActinicOffset   166
        #define Mem_B_AcclDaylightOffset  167
        #define Mem_B_RandomMode          168
        #define Mem_B_GyreOffset          169
        #define Mem_B_MoonMode            170
        #define Mem_B_LightsOffPerc       171
        #define Mem_B_FeedingSpeed        172
        #define Mem_B_WCSpeed             173
        #define Mem_B_EnableStorm         178
        #define Mem_B_ForceRandomTide     179
        #define Mem_B_ResetMemory         199
        void init_memory() {
          // Initialize Custom Memory Locations
          InternalMemory.write(Mem_B_MoonOffset,15);           //mb100
          InternalMemory.write(Mem_B_AtoHourInterval,1);       //mb101
          InternalMemory.write_int(Mem_I_Latitude,-21);        //mi108
          InternalMemory.write_int(Mem_I_Longitude,-147);      //mi110
          InternalMemory.write(Mem_B_AcclRiseOffset,1);        //mb112
          InternalMemory.write(Mem_B_AcclSetOffset,1);         //mb113
          InternalMemory.write(Mem_B_AcclDay,0);               //mb114
          InternalMemory.write(Mem_B_TideMin,10);              //mb117
          InternalMemory.write(Mem_B_TideMax,20);              //mb118
          InternalMemory.write(Mem_B_PumpOffset,80);           //mb119
          InternalMemory.write(Mem_B_FeedingDCPump,true);      //mb120
          InternalMemory.write(Mem_B_NightDCPump,false);       //mb121
          InternalMemory.write(Mem_B_NightSpeed,35);           //mb122
          InternalMemory.write(Mem_B_NightDuration,16);        //mb123
          InternalMemory.write(Mem_B_NTMSpeed,100);            //mb124
          InternalMemory.write(Mem_B_NTMDuration,50);          //mb125
          InternalMemory.write(Mem_B_NTMDelay,0);              //mb126
          InternalMemory.write(Mem_B_NTMTime,5);               //mb127
          InternalMemory.write(Mem_B_TideMode,0);              //mb143
          InternalMemory.write(Mem_B_CloudsEveryXDays,1);      //mb149
          InternalMemory.write(Mem_B_CloudChancePerDay,40);    //mb150
          InternalMemory.write(Mem_B_MinCloudDuration,5);      //mb151
          InternalMemory.write(Mem_B_MaxCloudDuration,10);     //mb152
          InternalMemory.write(Mem_B_MinCloudsPerDay,2);       //mb153
          InternalMemory.write(Mem_B_MaxCloudsPerDay,20);      //mb154
          InternalMemory.write(Mem_B_StartCloudAfterHour,12);  //mb155
          InternalMemory.write(Mem_B_StartCloudAfterMin,1);    //mb156
          InternalMemory.write(Mem_B_EndCloudBeforeHour,19);   //mb157
          InternalMemory.write(Mem_B_EndCloudBeforeMin,1);     //mb158
          InternalMemory.write(Mem_B_LightningChance,25);      //mb159
          InternalMemory.write(Mem_B_LightMode,1);             //mb160
          InternalMemory.write(Mem_B_LightOffset,10);          //mb161
          InternalMemory.write_int(Mem_I_RiseOffset,20);       //mi162
          InternalMemory.write_int(Mem_I_SetOffset,16);        //mi164
          InternalMemory.write(Mem_B_AcclActinicOffset,214);   //mb166
          InternalMemory.write(Mem_B_AcclDaylightOffset,214);  //mb167
          InternalMemory.write(Mem_B_RandomMode,true);         //mb168
          InternalMemory.write(Mem_B_GyreOffset,10);           //mb169
          InternalMemory.write(Mem_B_MoonMode,1);              //mb170
          InternalMemory.write(Mem_B_LightsOffPerc,1);         //mb171
          InternalMemory.write(Mem_B_FeedingSpeed,0);          //mb172
          InternalMemory.write(Mem_B_WCSpeed,0);               //mb173
          InternalMemory.write(Mem_B_ResetMemory,false);       //mb199
        #define NUMBERS_8x16
        #define Var_Tide         4
        #define Var_TideMode     5
        // Define Relay Ports by Name
        #define Return             1
        #define Heater             2
        #define Refugium           3
        #define MediaPump          4
        #define WhiteLeft          5
        #define BlueLeft           6
        #define Autotopoff         7
        #define Skimmer            8
        // Custom classes
        SunLocation sun;
        Tide tide;
        // Jebao Variables
        byte DCPumpMode, DCPumpSpeed, DCPumpDuration;
        // For Cloud and preset code
        int DaylightPWMValue=0;
        int ActinicPWMValue=0;
        int DaylightPWMValue0=0;        // For cloud code, channel 0
        int DaylightPWMValue2=0;        // For cloud code, chennel 2
        int ActinicPWMValue1=0;        // For cloud code, channel 0
        int ActinicPWMValue3=0;        // For cloud code, chennel 2
        // Needs to be global for DrawCustomGraph()
        int ScreenID=1;
        // Setup on controller startup/reset
          for (int a=0;a<SIZE(menu_items);a++)
    ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a); // Initialize Menu
          ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | !Port3Bit ;
          ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port7Bit  | Port8Bit;
          ReefAngel.LightsOnPorts = Port3Bit | Port5Bit | Port6Bit;
          ReefAngel.OverheatShutoffPorts =  Port2Bit ;
        ReefAngel.Relay.On( Return ); // Return Pump
       randomSeed(now()/SECS_PER_DAY);
          if (InternalMemory.read(Mem_B_ResetMemory))
            init_memory();
        DelayedOnFeedMode(Return); // DelayedOn after feed mode change only
        ReefAngel.Relay.Set(Refugium,!ReefAngel.Relay.Status(WhiteLeft));
        ReefAngel.Relay.Set(Refugium,!ReefAngel.Relay.Status(ReefAngel.DisplayedMenu==WATERCHANGE_MODE));
        ReefAngel.Relay.Set(Refugium,!ReefAngel.Relay.Status(ReefAngel.DisplayedMenu==FEEDING_MODE));
        ReefAngel.SingleATO(true,Autotopoff, InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
        ReefAngel.Relay.Set(Skimmer, ReefAngel.HighATO.IsActive());
        ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
        ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right jebao rw4
        ReefAngel.StandardHeater(Heater);
          // Added New features
          SetSun();               // Setup Sun rise/set lighting
          AcclimateLED();         // Apply acclimation dimming
          SetMoon();              // Setup Moon rise/set lighting
          FillInMoon();           // Fill in 5% to 0% gap in main LEDs
          LEDPresets();           // Set preset light levels
          CheckCloud();           // Check for cloud and lightning.
          UpdateLED();            // Set Lights on and off in sync with dimming
          SetTide();              // Set High/Low tide properties
          SetDCPump();            // Set DCPump modes
           ReefAngel.Portal( "troylong45" );
        ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
        void SetSun() {
          // Start acclimation routine
          int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
          int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
          byte acclDay=InternalMemory.read(Mem_B_AcclDay);
          // See if we are acclimating corals and decrease the countdown each day
          static boolean acclCounterReady=false;
          if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
          if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
            acclDay--;
            InternalMemory.write(Mem_B_AcclDay,acclDay);
          // End acclimation
          // Add some customizable offsets
          sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
          int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
          int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
          sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
          sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
          byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
          byte actinicOffset=InternalMemory.ActinicOffset_read();
          // Make sure light resets to zero at night.
          for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
          switch(InternalMemory.read(Mem_B_LightMode)) {
            case 0: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
              break;
            case 1: {
              // Daylights
              ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
              ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
              break;
          case 2: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
              break;
          case 3: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
              break;
          case 4: { // Reverse the actinics in the morning
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
          break;
    void SetMoon() {
      byte offset=InternalMemory.read(Mem_B_MoonOffset);
      byte startD=InternalMemory.read(Mem_B_PWMSlopeStartD);
      byte endD=InternalMemory.read(Mem_B_PWMSlopeEndD);
      byte timeD=InternalMemory.read(Mem_B_PWMSlopeDurationD);
      byte startA=InternalMemory.read(Mem_B_PWMSlopeStartA);
      byte endA=InternalMemory.read(Mem_B_PWMSlopeEndA);
      byte timeA=InternalMemory.read(Mem_B_PWMSlopeDurationA);
      time_t onTime=ScheduleTime(Moon.riseH, Moon.riseM,0);
      time_t offTime=ScheduleTime(Moon.setH, Moon.setM,0);
      time_t offsetOnTime=ScheduleTime(Moon.riseH, Moon.riseM,0)-(offset*60);
      time_t offsetOffTime=ScheduleTime(Moon.setH, Moon.setM,0)-(offset*60);
      byte actRiseH=(offsetOnTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actRiseM=((offsetOnTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      byte actSetH=(offsetOffTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actSetM=((offsetOffTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      static byte mp=MoonPhase();
      if (mp!=MoonPhase()) {
        InternalMemory.write(Mem_B_PWMSlopeEndD,mp);
        InternalMemory.write(Mem_B_PWMSlopeEndA,mp);
        mp=MoonPhase();
      moon_init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
      ReefAngel.PWM.SetDaylight(0);
      ReefAngel.PWM.SetActinic(0);
      switch(InternalMemory.read(Mem_B_MoonMode)) {
        case 0: {
          // Daylights
          ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
        case 1: {
          ReefAngel.PWM.SetDaylightRaw(PWMParabolaHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMParabolaHighRes(actRiseH,actRiseM,actSetH,actSetM, startD,endD,0));
          break;
      case 2: {
          ReefAngel.PWM.SetDaylightRaw(PWMSmoothRampHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSmoothRampHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
      case 3: {
          ReefAngel.PWM.SetDaylightRaw(PWMSigmoidHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSigmoidHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,0));
          break;
    void FillInMoon() {
      // Extend the sunrise/sunset to fill in gaps when fixtures shut off.
      int LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
      int onTime=NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())-(actinicOffset+(2*lightOffset));
      int offTime=NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())+(actinicOffset+(2*lightOffset));
      int moonVal=ReefAngel.PWM.GetDaylightValueRaw();
      int channelVal=PWMSlopeHighRes(onTime/60,onTime%60,offTime/60,offTime%60,0,100,lightOffset,0);
      if (ReefAngel.PWM.GetChannelValueRaw(1)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetDaylightValueRaw())
        ReefAngel.PWM.SetDaylightRaw(channelVal);
      if (ReefAngel.PWM.GetChannelValueRaw(3)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetActinicValueRaw())
        ReefAngel.PWM.SetActinicRaw(channelVal);
      DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
      ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
    void AcclimateLED() {
          if (acclDay > 0) {
            float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
            float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
            float endPerc;
            endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
            ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
            ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
            ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
            ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
#define LED_1to1      Box2_Port1
#define LED_2to1      Box2_Port2
#define LED_3to1      Box2_Port3
#define LED_BLUE      Box2_Port4
#define LED_WHITE     Box2_Port5
#define LED_MOON      Box2_Port6
#define LED_STORM     Box2_Port7
#define TRIGGER_STORM Box2_Port8
        void resetRelayBox(byte ID) {
  // toggle all relays except for the one selected
  for (int i=Box2_Port1;i<=Box2_Port4;i++) {
    if (i!=ID) ReefAngel.Relay.Auto(i);
void LEDPresets() {
  static byte lastPreset=0;
  DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
  ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
  DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
  ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
  if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
    if (lastPreset!=1) resetRelayBox(LED_1to1);
    DaylightPWMValue0=90*40.95;
    ActinicPWMValue1=10*40.95;
    DaylightPWMValue2=90*40.95;
    ActinicPWMValue3=10*40.95;
    lastPreset=1;
  if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
    if (lastPreset!=2) resetRelayBox(LED_1to1);
    DaylightPWMValue0=10*40.95;
    ActinicPWMValue1=90*40.95;
    DaylightPWMValue2=10*40.95;
    ActinicPWMValue3=90*40.95;
    lastPreset=2;
  if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
    if (lastPreset!=3) resetRelayBox(LED_2to1);
    DaylightPWMValue0=60*40.95;
    ActinicPWMValue1=40*40.95;
    DaylightPWMValue2=60*40.95;
    ActinicPWMValue3=40*40.95;
    lastPreset=3;
  if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
    if (lastPreset!=4) resetRelayBox(LED_2to1);
    DaylightPWMValue0=40*40.95;
    ActinicPWMValue1=60*40.95;
    DaylightPWMValue2=40*40.95;
    ActinicPWMValue3=60*40.95;
    lastPreset=4;
  if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
    if (lastPreset!=5) resetRelayBox(LED_3to1);
    DaylightPWMValue0=75*40.95;
    ActinicPWMValue1=25*40.95;
    DaylightPWMValue2=75*40.95;
    ActinicPWMValue3=25*40.95;
    lastPreset=5;
  if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
    if (lastPreset!=6) resetRelayBox(LED_3to1);
    DaylightPWMValue0=25*40.95;
    ActinicPWMValue1=75*40.95;
    DaylightPWMValue2=25*40.95;
    ActinicPWMValue3=75*40.95;
    lastPreset=6;
  if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
    if (lastPreset!=9) resetRelayBox(LED_BLUE);
    ActinicPWMValue1=80*40.95;
    ActinicPWMValue3=80*40.95;
    lastPreset=9;
  if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
    if (lastPreset!=10) resetRelayBox(LED_BLUE);
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=10;
  if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
    if (lastPreset!=11) resetRelayBox(LED_WHITE);
    DaylightPWMValue0=80*40.95;
    ActinicPWMValue1=0;
    DaylightPWMValue2=80*40.95;
    ActinicPWMValue3=0;
    lastPreset=11;
  if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
    if (lastPreset!=12) resetRelayBox(LED_WHITE);
    lastPreset=12;
  if (ReefAngel.Relay.isMaskOn(LED_MOON)) {
    if (lastPreset!=13) resetRelayBox(LED_MOON);
    DaylightPWMValue=4095;
    ActinicPWMValue=4095;
    lastPreset=13;
  if (ReefAngel.Relay.isMaskOff(LED_MOON)) {
    if (lastPreset!=14) resetRelayBox(LED_MOON);
    DaylightPWMValue=0;
    ActinicPWMValue=0;
    lastPreset=14;
// Write updated values to the channels
void UpdateLED() {
  ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
  ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
  ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
  ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
  ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
  ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
  byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
  if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
  if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
void SetTide() {
  byte nightSpeed=InternalMemory.read(Mem_B_NightSpeed);
  byte tideMin=InternalMemory.read(Mem_B_TideMin);
  byte tideMax=InternalMemory.read(Mem_B_TideMax);
  // Set tide offsets
  tide.SetOffset(tideMin, tideMax);
  // Set tide speed. Slope in/out of Night Mode
  tide.SetSpeed(PWMSlope(sun.GetRiseHour()-1,sun.GetRiseMinute(),
    sun.GetSetHour(),sun.GetSetMinute(),nightSpeed+tideMin,DCPumpSpeed,120,nightSpeed+tideMin));
  // Show tide info on portal
  ReefAngel.CustomVar[Var_Tide]=tide.CalcTide();
void SetDCPump() {
  int ntmDelay=InternalMemory.read(Mem_B_NTMDelay)*60;
  int ntmTime=InternalMemory.read(Mem_B_NTMTime)*60;
  boolean nightDCPump=InternalMemory.read(Mem_B_NightDCPump);
  boolean feedingDCPump=InternalMemory.read(Mem_B_FeedingDCPump);
  static time_t t;
  ReefAngel.DCPump.FeedingSpeed=InternalMemory.read(Mem_B_FeedingSpeed);
  ReefAngel.DCPump.WaterChangeSpeed=InternalMemory.read(Mem_B_WCSpeed);
  DCPumpMode=InternalMemory.DCPumpMode_read();
  DCPumpSpeed=InternalMemory.DCPumpSpeed_read();
  DCPumpDuration=InternalMemory.DCPumpDuration_read();
  if ((now()-t > ntmDelay && now()-t < ntmTime+ntmDelay) && feedingDCPump) {
    // Post feeding mode
    DCPumpMode=Smart_NTM;
    DCPumpSpeed=InternalMemory.read(Mem_B_NTMSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
  } else if (!sun.IsDaytime() && nightDCPump) {
    DCPumpMode=Night;
    DCPumpSpeed=InternalMemory.read(Mem_B_NightSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NightDuration);
  } else {
    if (DCPumpMode!=Night && ReefAngel.DCPump.Mode==Night)
      ReefAngel.DCPump.SetMode(Night_Stop,0,0);
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
    t=now(); // Run post feeding mode when this counter stops
  } else if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
    // Not needed anymore.
    // ReefAngel.DCPump.SetMode(Constant,25,0);
  } else {
    if ((DCPumpMode==Smart_NTM) || (DCPumpMode==ShortPulse)) DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
    (DCPumpMode==Custom) ? DCPumpCustom() : ReefAngel.DCPump.SetMode(DCPumpMode,DCPumpSpeed,DCPumpDuration);
void RefugiumLight() {if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
        ReefAngel.Relay.On(Refugium);} }
void DCPumpCustom() {
  static boolean changeMode;
  byte rcSpeed, rcSpeedAS;
  // Define new modes
  const int BHazard=15;
  const int RA_ReefCrest=16;
  const int RA_Lagoon=17;
  const int RA_TidalSwell=18;
  const int RA_Smart_NTM=19;
  const int RA_ShortPulse=20;
  const int RA_LongPulse=21;
  byte tideSpeed=tide.CalcTide();
  byte tideMode=InternalMemory.read(Mem_B_TideMode);
  float pumpOffset=(float) InternalMemory.read(Mem_B_PumpOffset)/100;
  byte RandomModes[]={ ReefCrest, TidalSwell, Lagoon, ShortPulse, LongPulse, BHazard, Else, Sine };
//  if (now()%SECS_PER_DAY!=0 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
//  if (now()%SECS_PER_DAY==0 && changeMode) {
  if (now()%(6*SECS_PER_HOUR)!=10 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
  if (now()%(6*SECS_PER_HOUR)==10 && changeMode) {
    tideMode=random(100)%sizeof(RandomModes);
    InternalMemory.write(Mem_B_TideMode,tideMode);
    changeMode=false;
  // Choose another random mode if triggered
  if (InternalMemory.read(Mem_B_ForceRandomTide)) {
    InternalMemory.write(Mem_B_ForceRandomTide,false);
  ReefAngel.CustomVar[Var_TideMode]=tideMode+1;
  switch (RandomModes[tideMode]) {
    case ReefCrest: {
      ReefAngel.DCPump.SetMode(ReefCrest,tideSpeed,DCPumpDuration);
      return;
      break;
    case Lagoon: {
      ReefAngel.DCPump.SetMode(Lagoon,tideSpeed,DCPumpDuration);
      return;
      break;
    case TidalSwell: {
      ReefAngel.DCPump.SetMode(TidalSwell,tideSpeed,DCPumpDuration);
      return;
      break;
    case Smart_NTM: {
      ReefAngel.DCPump.SetMode(Smart_NTM,tideSpeed,DCPumpDuration);
      return;
      break;
    case ShortPulse: {
      ReefAngel.DCPump.SetMode(ShortPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case LongPulse: {
      ReefAngel.DCPump.SetMode(LongPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case RA_ReefCrest: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case RA_Lagoon: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration,false);
      break;
    case RA_TidalSwell: {
      rcSpeed=TidalSwellMode(tideSpeed,true);
      rcSpeedAS=TidalSwellMode(tideSpeed,false);
      break;
    case RA_Smart_NTM: {
      rcSpeed=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_ShortPulse: {
      rcSpeed=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_LongPulse: {
      rcSpeed=LongPulseMode(0,tideSpeed,DCPumpDuration,true);
      rcSpeedAS=LongPulseMode(0,tideSpeed,DCPumpDuration,false);
      break;
    case Else: {
      rcSpeed=ElseMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ElseMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case BHazard: {
      rcSpeed=millis()%1200>800?tideSpeed:0;
      rcSpeedAS=millis()%1200<400?0:tideSpeed;
      break;
    case Sine: {
      rcSpeed=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,true);
      rcSpeedAS=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,false);
      break;
    default: {
      rcSpeed=tideSpeed;
      rcSpeedAS=tideSpeed;
      pumpOffset=(float) InternalMemory.read(Mem_B_GyreOffset)/100;
  ReefAngel.DCPump.SetMode(Custom,rcSpeedAS*pumpOffset,tide.isOutgoing());
  ReefAngel.DCPump.SetMode(Custom,rcSpeed,tide.isIncoming());
void NextDCPumpMode() {
      DCPumpMode++;
      if (DCPumpMode > 12) {
        DCPumpMode=0;
        DCPumpSpeed=50; // Constant
      } else if (DCPumpMode == 1) {
        DCPumpSpeed=40; // Lagoon
      } else if (DCPumpMode == 2) {
        DCPumpSpeed=45; // Reef Crest
      } else if (DCPumpMode == 3) {
        DCPumpSpeed=55; DCPumpDuration=10; // Short Pulse
      } else if (DCPumpMode == 4) {
        DCPumpSpeed=55; DCPumpDuration=20; // Long Pulse
      } else if (DCPumpMode == 5) {
        DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration); // Smart_NTM
      } else if (DCPumpMode == 6) {
        DCPumpSpeed=50; DCPumpDuration=10; // Smart_TSM
      } else if (DCPumpMode == 7) {
        DCPumpMode=9; // Night
      } else if (DCPumpMode == 10) {
        DCPumpSpeed=65; DCPumpDuration=5; // Storm
      } else if (DCPumpMode == 11) {
        DCPumpSpeed=45; DCPumpDuration=10; // Custom
      if (DCPumpMode!=InternalMemory.DCPumpMode_read())
        InternalMemory.DCPumpMode_write(DCPumpMode);
      if (DCPumpSpeed!=InternalMemory.DCPumpSpeed_read())
        InternalMemory.DCPumpSpeed_write(DCPumpSpeed);
      if (DCPumpDuration!=InternalMemory.DCPumpDuration_read())
        InternalMemory.DCPumpDuration_write(DCPumpDuration);
        // Menu Code
void MenuEntry1() {
  ReefAngel.FeedingModeStart();
void MenuEntry2() {
void MenuEntry3() {
  ReefAngel.ATOClear();
void MenuEntry4() {
      NextDCPumpMode();
void MenuEntry5() {
  ReefAngel.SetupCalibratePH();
void MenuEntry6() {
  ReefAngel.OverheatClear();
void MenuEntry7() {
  ReefAngel.SetupDateTime();
void MenuEntry8() {
      // Toggle refugium light between on/auto.
      ReefAngel.Relay.Override(Refugium, ReefAngel.Relay.Status(Refugium)+1);
// Custom Main Screen
void DrawCustomMain() {
  const int NumScreens=4;
  static boolean drawGraph=true;
  // Main Header
  // ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
  ReefAngel.LCD.DrawDate(5,2);
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
      break;
    case 1: { DrawStatus(5,40); break; }
    case 2: { DrawSunMoon(5,40); break; }
    case 3: { DrawClouds(5,50); break; }
  // Draw Relays
  DrawRelays(12,94);
  // Date+Time
  // ReefAngel.LCD.DrawDate(5,122);
  if (ReefAngel.Joystick.IsLeft()) {
    ScreenID--; drawGraph=true;
  if (ReefAngel.Joystick.IsRight()) {
    ScreenID++; drawGraph=true;
  if (ScreenID<0) ScreenID=NumScreens-1;
  if (ScreenID>=NumScreens) ScreenID=0;
void DrawCustomGraph() {
  if (ScreenID==0)
    ReefAngel.LCD.DrawGraph(5, 40);
void DrawParams(int x, int y) {
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
  // Temp and PH
  y+=2;
  ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
  y+=6;
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
  y+=5;
  ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
  y+=12;
 // DC Pump Mode
      ReefAngel.LCD.DrawText(0,255,x,y,"DC:"); x+=20;
      ReefAngel.LCD.Clear(DefaultBGColor,x,y,t+(128-t),y+8);
      if (DCPumpMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,x,y,"Constant");
      else if (DCPumpMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Lagoon");
      else if (DCPumpMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Reef Crest");
      else if (DCPumpMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Short Pulse");
      else if (DCPumpMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Long Pulse");
      else if (DCPumpMode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Smart NTM");
      else if (DCPumpMode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Tidal Swell");
      else if (DCPumpMode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,x,y,"Night");
      else if (DCPumpMode == 10) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,0,x,y,"Storm");
      else if (DCPumpMode == 11) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,x,y,"Custom");
      y+=10; x=t;
      ReefAngel.LCD.DrawText(0,255,x,y,"DC Speed:"); x+=60;
      ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,DCPumpSpeed); x+=15;
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,"/"); x+=10;
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,DCPumpDuration);
      y+=10; x=t;
  // Display Acclimation timer
  if (acclDay > 0) {
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
    ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
  } else {
void DrawSunMoon(int x, int y) {
  char buf[16];
  int t=x;
  y+=2;
  /// Display Sunrise / Sunset
  sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
  ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
  sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
  y+=15; x=t;
  /// Display Moonrise / Moonset
  sprintf(buf, "%02d:%02d", Moon.riseH, Moon.riseM);
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
  sprintf(buf, "%02d:%02d", Moon.setH, Moon.setM); x+=36;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:"); x+=21;
  ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); x+=36;
  if (Moon.isUp) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"@");
    else ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"_");
  y+=10; x=t;
  // MoonPhase
  ReefAngel.LCD.DrawText(0,255,x,y,"Moon:");
  ReefAngel.LCD.Clear(DefaultBGColor,x+32,y,128,y+8);
  ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,MoonPhaseLabel());
  y+=10; x=t;
  // MoonLight %
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLights:"); x+=68;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor,x,y,1);
  x+=5*(intlength(ReefAngel.PWM.GetDaylightValue())+1);
  ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "%");
void DrawRelays(int x, int y) {
  // Draw Relays
  ReefAngel.LCD.DrawOutletBox(x, y, TempRelay);
  y+=12;
  y+=12;
  TempRelay = ReefAngel.Relay.RelayDataE[1];
  TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
  TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
void DelayedOnFeedMode(byte relay) {
  static unsigned long startTime=now();
  if ( (startTime==LastStart || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) && ReefAngel.HighATO.IsActive()) {
    ReefAngel.Relay.On(relay);
  } else {
    ReefAngel.Relay.DelayedOn(relay);
#define Clouds_Every_X_Days InternalMemory.read(Mem_B_CloudsEveryXDays)
#define Cloud_Chance_per_Day InternalMemory.read(Mem_B_CloudChancePerDay)
// Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration InternalMemory.read(Mem_B_MinCloudDuration)
#define Max_Cloud_Duration InternalMemory.read(Mem_B_MaxCloudDuration)
#define Min_Clouds_per_Day InternalMemory.read(Mem_B_MinCloudsPerDay)
#define Max_Clouds_per_Day InternalMemory.read(Mem_B_MaxCloudsPerDay)
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(InternalMemory.read(Mem_B_StartCloudAfterHour),InternalMemory.read(Mem_B_StartCloudAfterMin))
#define End_Cloud_Before NumMins(InternalMemory.read(Mem_B_EndCloudBeforeHour),InternalMemory.read(Mem_B_EndCloudBeforeMin))
#define Lightning_Chance_per_Cloud InternalMemory.read(Mem_B_LightningChance)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Slow};
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      // Commenting out to see if it's interfering with our other seed.
      // randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
        // if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
        if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
  if (ReefAngel.Relay.isMaskOn(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,false);
  if (ReefAngel.Relay.isMaskOff(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,true);
  if (InternalMemory.read(Mem_B_EnableStorm)) return;
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOff(TRIGGER_STORM))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(TRIGGER_STORM);    // Here, too.
    //is it time for cloud yet?
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
      DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
        if (lightningchance && second()%40<8)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOn(TRIGGER_STORM) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(100);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left and right both.
      if (r<14) {
        DaylightPWMValue0=4095;
        DaylightPWMValue2=4095;
        ActinicPWMValue1=4095;
        ActinicPWMValue3=4095;
      } else if (r<17) {
        DaylightPWMValue0=100;
      } else {
        DaylightPWMValue2=100;
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      ReefAngel.CustomVar[0]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      ReefAngel.CustomVar[1]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    ReefAngel.CustomVar[2]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        ReefAngel.CustomVar[7]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 2.
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(2);   // Use the channel number you're flashing here
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
  if (n>cend) return (int) PWMStart;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
new code for moms tank
        #define Mem_B_AtoHourInterval     101    //MB101
        #define Mem_B_LightsOffPerc       102    //MB102
          InternalMemory.write(Mem_B_AtoHourInterval,1);       //MB101
          InternalMemory.write(Mem_B_LightsOffPerc,0);         //MB102
    #define AUTOTOPOFF        1
    #define SKIMMER           2//changed SKIMMER FROM DIMMING
    #define BLUELED           3
    #define WHITELED          4
    #define HEATER            5
    #define POWERHEAD         6
    #define FAN               7
    #define RETURN            8
    //dimmingchannel call out
    // 0    blue led channel
    // 1    white led channel
    // 2
    // 3
    // 4    powerhead left
    // 5    powerhead right
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit ;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit ;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit ;
    ReefAngel.OverheatShutoffPorts = Port5Bit ;
   // InternalMemory.OverheatTemp_write( 800 ); //removed temp
    ReefAngel.Relay.On( SKIMMER );//changed SKIMMER FROM DIMMING
    ReefAngel.Relay.On( POWERHEAD );
    ReefAngel.Relay.On( FAN );
    ReefAngel.Relay.On( RETURN );
    DelayedOnFeedMode(RETURN); // DelayedOn after feed mode change only //new
    ReefAngel.Relay.Set(SKIMMER, ReefAngel.HighATO.IsActive());//new
    ReefAngel.SingleATO(true, AUTOTOPOFF , InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
    ReefAngel.StandardHeater ( HEATER );
    ReefAngel.PWM.Channel0PWMParabola();
    ReefAngel.PWM.Channel1PWMParabola();
    ReefAngel.DCPump.ExpansionChannel[0] = None;
//blue led relay port 3/BLUELED +dimming channel 0
if (ReefAngel.PWM.GetChannelValue(0) >  InternalMemory.read(Mem_B_LightsOffPerc)) {
   // Value over MB102
   ReefAngel.Relay.On(BLUELED);
} else {
   // otherwise, value IS MB102 or less (which should never happen)
   ReefAngel.Relay.Off(BLUELED);
//white led relay port 4/WHITELED +dimming channel 1
    if (ReefAngel.PWM.GetChannelValue(1) >  InternalMemory.read(Mem_B_LightsOffPerc)) {
   // Value over MB102
   ReefAngel.Relay.On(WHITELED);
} else {
   ReefAngel.Relay.Off(WHITELED);
//DelayedOn after feed mode change only //NEW
  } else {
  }//NEW
troylong45
Re: new to coding
FIXED i have an issue
i dont see how to use led coral acclimation no option to turn on
i have 4 relay boxs showing up and only have one im guessing the 4th box is a virtual box
i have rf expansion showing up and dont want
Re: new to coding
The acclimation is used by setting the number of days in tr memory location Mem_B_AcclDay
If you change the Box3 stuff to Box1 it will move everything to that box and the other two will disappear.
Make sure there's no references to the RF module to get rid of that. It has to be removed or replaced by DCPump or it will still come up by the compiler.
troylong45
Re: new to coding
Makes since lol. I'll edit that later tight now I'm going to leave it be to make sure everything is working right so far ok I haven't seen a cloud or Strom yet but I know it is more random then coralux storm was and I'm not worried about it as long as it happens I'll give it a week and check guaphs then. Thanks
Re: new to coding
If you're using my code you should be able to trigger a cloud/lightning with the LED_STORM relay. Turning it on will make lightning effects every minute. Off should trigger the next cloud/lightning effect.
troylong45
Re: new to coding
I might have messed something up or removed something I'll have to look them over I flipped on box3 port8 but didn't see anything I'll look at it after I get my harness made for my 2nd light
troylong45
Re: new to coding
looks like every thing is copyied right for storm and cloud from ur ino. did u set ur channels to be separte maybe thats why i dont see storm happening maybe its on the other 2 channels i need to get hooked up when my wires get here
troylong45
Re: new to coding
Yea storm definitely not working or the switch for it. And the switch for ledpreset 3to1 off is same as on(LEDPRESET 3TO1 IS OK)
Re: new to coding
No its not... On is 75/25 off is 25/75...
You have the pwm one or the analog drivers?
troylong45
Re: new to coding
Never mind it' working after I edited code from box3 to box1 and uploaded. but storm is still not working looks right to me. Maybe a connection or override to the led channels? I'm going to look at my original code u made months ago and see why that storm works and not the one I edited from ur ino
troylong45
Re: new to coding
does this need to be in the loop(i guess its loop ) for cloud to work i dont see this in ur code lee but its in the old one u did for me months ago
CheckCloud(); // Apply cloud routine(SRY IS IN CODE)
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
Re: new to coding
You should have the SetChannelRaw in updateLED and you most certainly do need CheckCloud in loop and I most certainly do have it in mine.
Re: new to coding
You have it in the code you posted...did you remove it?
troylong45
Re: new to coding
sry i over looked the check cloud i see it.
ok so those do not need added..
its beond me lol im differently able to under stand the writing a little more then my first day im guessing its something i screwed up the link between cloud/storm and dimming or something maybe if i swap the storm cloud from this one
    SunLocation sun;
    int DaylightPWMValue=0;        // For cloud code
    int Latitude=-18;
    int Longitude=147;
        ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
        ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
        sun.Init(Latitude,Longitude);
        void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Min_Cloud_Duration 7
        #define Max_Cloud_Duration 7
        #define Min_Clouds_per_Day 1
        #define Max_Clouds_per_Day 2
        #define Start_Cloud_After NumMins(12,00)
        #define End_Cloud_Before NumMins(21,00)
          byte LightningModes[] = {Mega2,Mega,Mega};
          static int LastNumMins=0;
        #else
        #endif
              if (cloudchance)
          if (cloudchance)
              DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
              case Calm:
                break;
              case Mega:
                  // Send the trigger
                  Strike();
                break;
              case Mega2:
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
            /*ReefAngel.LCD.Clear(255,0,120,132,132);
             ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
              int x=0;
              else x=17;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
              ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
              else x=35;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
              ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
            //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
              int x=0;
              if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
              else x=57;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
              else x=75;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
                ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
        void Strike()
            // Flash on
            int newdata=4095;
            Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
          cstart*=60;
          cend*=60;
        ReefAngel.DayLights( Port2 );
        ReefAngel.Relay.DelayedOn( Port3 );
        ReefAngel.Relay.DelayedOn( Port4 );
        ReefAngel.StandardHeater( Port6 );
        ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive());
        ReefAngel.SingleATOLow( Port7 );
        ReefAngel.PWM.SetChannel(0,0); // Make sure we're at 0% at night
        ReefAngel.PWM.Channel0PWMParabola(); // Set Channel0 based on Parabola and Memory values
        ReefAngel.PWM.Channel1PWMParabola(); // Set Chanenl1 based on Parabola and Memory values
        DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
        ReefAngel.DDNS( "209.18.47.61" ); // Your DDNS is troylong45-209.18.47.61.myreefangel.com
troylong45
Re: new to coding
ok i put this code above and changed the cloud and effect channel to work and storm is working but what is the issue with the storm in the ino i copyed and edited from yous lee if maybe i can just add the effects switch to this code below to activate at will.
    #include <Tide.h>
    // Custom menus
    prog_char menu1_label[] PROGMEM = "Feeding Mode";
    prog_char menu3_label[] PROGMEM = "ATO Clear";
    prog_char menu4_label[] PROGMEM = "Overheat Clear";
    prog_char menu5_label[] PROGMEM = "PH Calibration";
    prog_char menu6_label[] PROGMEM = "Date / Time";
    #define Mem_B_PrintDebug      198
      InternalMemory.write_int(Mem_I_Latitude,21);
      InternalMemory.write_int(Mem_I_Longitude,-73);
      InternalMemory.write(Mem_B_AcclRiseOffset,4);
      InternalMemory.write(Mem_B_AcclSetOffset,2);
      InternalMemory.write(Mem_B_LightOffset,20);
      InternalMemory.write_int(Mem_I_RiseOffset,-1);
      InternalMemory.write_int(Mem_I_SetOffset,-1);
      InternalMemory.write(Mem_B_AcclActinicOffset,100);
      InternalMemory.write(Mem_B_AcclDaylightOffset,100);
    #define Return             1
    #define Heater             2
    #define WhiteLeft          3
    #define BlueLeft           4
    #define WhiteRight         5
    #define BlueRight          6
    #define Skimmer            8
    // Custom classes
    SunLocation sun;
    Tide tide;
    int ScreenID=1;
      ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
      ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
      ReefAngel.WaterChangePorts = Port1Bit | Port2Bit  | Port7Bit  | Port8Bit;
      ReefAngel.LightsOnPorts = Port3Bit | Port5Bit;
      ReefAngel.OverheatShutoffPorts = Port2Bit;
    ReefAngel.Relay.On( Port1 ); // Return Pump
        init_memory();
    ReefAngel.SingleATOLow( Port7 ); // Auto top off
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right Jebao RW4
      // Lighting and Flow
      LEDPresets();
      UpdateLED();
    void SetSun() {
        acclDay--;
      // End acclimation
        case 0: {
          // Daylights
          // Actinics
          break;
        case 1: {
          // Daylights
          // Actinics
          break;
      case 2: {
          // Daylights
          // Actinics
          break;
      case 3: {
          // Daylights
          // Actinics
          break;
          // Daylights
          // Actinics
          break;
      if (acclDay > 0) {
        float endPerc;
    #define LED_1to1  Box1_Port1
    #define LED_4to1  Box1_Port2
    #define LED_3to1  Box1_Port3
    #define LED_2to1  Box1_Port4
    #define LED_BLUE  Box1_Port5
    #define LED_WHITE Box1_Port6
    #define LED_STORM Box1_Port8
      for (int i=Box1_Port1;i<=Box1_Port4;i++) {
    void LEDPresets() {
        lastPreset=1;
        lastPreset=2;
        lastPreset=3;
        lastPreset=4;
        lastPreset=5;
        lastPreset=6;
      if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
        if (lastPreset!=7) resetRelayBox(LED_4to1);
        ActinicPWMValue1=20*40.95;
        ActinicPWMValue3=20*40.95;
        lastPreset=7;
      if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
        if (lastPreset!=8) resetRelayBox(LED_4to1);
        DaylightPWMValue0=20*40.95;
        DaylightPWMValue2=20*40.95;
        lastPreset=8;
        lastPreset=9;
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=10;
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=11;
        lastPreset=12;
    void UpdateLED() {
      if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(WhiteRight); else ReefAngel.Relay.Off(WhiteRight);
      if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(BlueRight); else ReefAngel.Relay.Off(BlueRight);
    // Menu Code
    void MenuEntry1() {
    void MenuEntry2() {
    void MenuEntry3() {
    void MenuEntry4() {
    void MenuEntry5() {
    void MenuEntry6() {
      // Main Header
      // Param Header
      DrawParams(5,14);
      switch (ScreenID) {
        case 0:
          break;
      // Draw Relays
      DrawRelays(12,94);
      // Date+Time
      if (ScreenID==0)
      char buf[16];
      // Temp and PH
      y+=2;
      y+=6;
      y+=5;
      int t=x;
      } else {
      } else {
      y+=12;
      if (acclDay > 0) {
      } else {
      char buf[16];
      int t=x;
      y+=2;
      y+=15; x=t;
      // Draw Relays
    void DelayedOnModes(byte relay) {
      if ( (startTime==LastStart) && ReefAngel.HighATO.IsActive()) {
      } else {
     void CheckCloud()
        #else
        #endif
              if (cloudchance)
          if (cloudchance)
              case Calm:
                break;
              case Mega:
                  // Send the trigger
                  Strike();
                break;
              case Mega2:
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              int x=0;
              else x=17;
              else x=35;
              int x=0;
              else x=57;
              else x=75;
        void Strike()
            // Flash on
            int newdata=4095;
            Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
          cstart*=60;
          cend*=60;
troylong45
Re: new to coding
hey lee some reason im not seeing storm on my lights i need to edit the storm i guess see anything wrong with it?
troylong45
Re: new to coding
wait i think i found the problem its says in storm code dont use less then 6 mins minimum for cloud and i was using 1min
troylong45
Re: troylong45 ino
If i want to set a max dc pump speed in this code how do i do that
troylong45
Re: troylong45 ino
Lnevo if i want water change mode to overide a relay marked Refugium to on then then water change is reset to off to return to it's auto state i tried this but I'm missing something it was a cut from ur ino.
And would like relay Refugium Auto to be on opposit from relay WhiteLeft plus and minis X hours (which i will add into memory) to overlap ph
as well the Refugium menu option on the head unit is not cycling it
And i was looking at your code and seen "delayedmode" on skimmer and says "delayed on" after mode change I tried fiddling with it but didn't get it to work or compile . I want Return to delay on after feed mode only right now it is doing it after reboot,after wc, and after feed.
Re: troylong45 ino
Re: troylong45 ino
Whats the compile errors
troylong45
Re: troylong45 ino
O... the code is already in the ino thats y is wouldnt lol . now that i relize the code was there already i changed the delayport to the delayedon
now on reboot it dont delay which is 2 of 3 things working the delay on feed,no delay on reboot. now need to stop delay on water change mode
this in my loop
this is at the end of my controller display setting and befor storm code
  } else {
Re: troylong45 ino
  } else {
troylong45
Re: troylong45 ino
ok also i was wondering what the meaning of high ato. i was trying to search for this info and i seen it was for a skimmer like your code is but since its for my return i guess i dont need high ato in there ? and last time was for power outage ?
Re: troylong45 ino
I dont want my skimmer running when the water level is to high. I wrote this so if the ra rebooted it wasn't off for 10 minutes
troylong45
Re: troylong45 ino
its working ... thanks again . i also replaced virtual switch 4to1 led to turn storm on or off instead of memory and added all the storm variables in memory to edit so well see how it all goes during day light
          InternalMemory.write(Mem_B_CloudChancePerDay,50);    //mb150
          InternalMemory.write(Mem_B_MinCloudDuration,6);      //mb151
          InternalMemory.write(Mem_B_MaxCloudsPerDay,8);       //mb154
          InternalMemory.write(Mem_B_StartCloudAfterHour,10);  //mb155
          InternalMemory.write(Mem_B_StartCloudAfterMin,00);   //mb156
          InternalMemory.write(Mem_B_EndCloudBeforeHour,22);   //mb157
          InternalMemory.write(Mem_B_EndCloudBeforeMin,00);    //mb158
          InternalMemory.write(Mem_B_LightningChance,50);      //mb159
changed all LED_STORM to TRIGGER_STORM and added new LED_STORM for enable mode
  if (cloudchance)
    SlowStrike();
troylong45
Re: troylong45 ino
Can help me again with my code again i dont know why the wave makers arenot doing lunar/tide part any more for few months it hasent
And the storm will turn off the lights during lightning at times idk if it is dimming tolow or above range is there away to give it a number it cant go past so they dont turn offat times
