skimmer on time schedule
Ask in here.
Reefology
Post by Reefology »
Hi, I'd like to experiment with having my skimmer on a reverse daylight schedule and think I have to add the line below to void loop section.
ReefAngel.StandardLights( Port5,23,0,13,0 );//Protein skimmer on 11pm, off 1pm
my question is, can I control schedule from the portal? And if so, what code do I need?
thanks
Re: skimmer on time schedule
Use this:
ReefAngel.StandardLights( Port5 );
Reefology
Post by Reefology »
can I then control that port via the portal?
Yeap :)
Reefology
Post by Reefology »
Awesome thanks
Reefology
Post by Reefology »
actually changed port 4 and 5 but I can't find them in the portal?
You need to change the internal memory settings.
Reefology
Post by Reefology »
how do I do that?
Go to the portal and click internal memory
Reefology
Post by Reefology »
only gives me an option to adjust daylight schedule which I don't want to change. looking to adjust skimmer schedule.
thanks
You are using standard lights. That is the one.
Reefology
Post by Reefology »
I need that for my lights. what if I want to have a schedule for my skimmer? would the code in my first post work?
Are you using internal memory code for your lights too?
Can you post your entire code?
The code in the first post works, but you won't be able to change on the portal.
Reefology
Post by Reefology »
so like this in port 4 and 5?
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardLights( Port4,23,0,13,0 );//Protein skimmer on 11pm, off 1pm
    ReefAngel.StandardLights( Port5,2,0,19,0 );//Moomlights 2am-7pm
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.DaylightChannel = None;//no pump=None, pump=AntiSync
Ahh. now it makes sense.
So, there is no way to use the portal to adjust a second schedule.
You can do it with the android app or issuing web commands though.
For web commands, check here:
http://forum.reefangel.com/viewtopic.php?f=7&t=1541
