skimmer on time schedule
Reefology
Hi, I'd like to experiment with having my skimmer on a reverse daylight schedule and think I have to add the line below to void loop section.
ReefAngel.StandardLights( Port5,23,0,13,0 );//Protein skimmer on 11pm, off 1pm
my question is, can I control schedule from the portal? And if so, what code do I need?
thanks
thanks
Reefology
Reefology
Reefology
Reefology
Reefology
Re: skimmer on time schedule
only gives me an option to adjust daylight schedule which I don't want to change. looking to adjust skimmer schedule.
thanks
thanks
Reefology
I need that for my lights. what if I want to have a schedule for my skimmer? would the code in my first post work?
Are you using internal memory code for your lights too?
Can you post your entire code?
The code in the first post works, but you won't be able to change on the portal.
Reefology
so like this in port 4 and 5?
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights( Port4,23,0,13,0 );//Protein skimmer on 11pm, off 1pm
ReefAngel.StandardLights( Port5,2,0,19,0 );//Moomlights 2am-7pm
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.DosingPumpRepeat3( Port8 );
ReefAngel.DCPump.DaylightChannel = None;//no pump=None, pump=AntiSync
Ahh. now it makes sense.
So, there is no way to use the portal to adjust a second schedule.
You can do it with the android app or issuing web commands though.
For web commands, check here:
http://forum.reefangel.com/viewtopic.php?f=7&t=1541
