I've had problems with the stability of my salinity probe since I first received it. I tried moving it to more temperature stable parts of the sump, and I tried to remove any possible air bubbles.
However, now it only registers a salinity of 5.9, which I believe is indicative of an error. If I try to calibrate it, I only see 0.
Is there any way to determine if this is an issue with the probe or the module?
-Steve
Salinity Showing 5.9
sbidny
Re: Salinity Showing 5.9
Try resetting the module. Make sure it has power and that the power light is on. Try connecting it directly to the relay box as a test. Also if you have an extra cable. More than likely it's the probe. Mine's dead too, I haven't changed it yet though either (and I have a spare..)
