After removing and reinstalling the RA Uapp on iPad, and not use the cloud server settings, the Uapp is now working great. love the new interface. Thanks, Roberto.rimai wrote:If it says cloud server connecting, you entered something in the cloud server field. You must remove it or the app will try to connect through the cloud server and your controller is not capable.
The cloud server is a feature that will be used on a board not yet released.
I'm going to remove that from the app, since it is causing so much confusion.
So, make sure you don't use the cloud server settings or you will never be able to make the app work for you.
Universal App
bboss
Re: Universal App
Naptalene
Re: Universal App
+1 and the web interface is looking great as well (when you login to the unit with your IP:2000/wifi)
The only thing that caught me off guard was my labels for the relay wouldn't show but then I found the pull down menu lol.
troylong45
Re: Universal App
How do view relay activity like in portal I can get pwm channel but cant figure out how to see relay graph. The program you put ur ip address in url
bboss
Re: Universal App
I was wondering the same thing. I use rely activity graphs to verify if my code is working correctly.troylong45 wrote:How do view relay activity like in portal I can get pwm channel but cant figure out how to see relay graph. The program you put ur ip address in url
Re: Universal App
Roberto was working on this. You could graph the value of R (main relay box) or R1 (relay box 1). It may he hard to read though because its the binary value of the relay box status.
troylong45
Re: Universal App
Looks like it only gives me 1 ready for 2 and it goes from -200 to 0 to 200 scale with some reading of 2 163 and other numbers but only a single line of itlnevo wrote:Roberto was working on this. You could graph the value of R (main relay box) or R1 (relay box 1). It may he hard to read though because its the binary value of the relay box status.
Re: Universal App
They are the decimal representation of the binary state of each relay. So if all relays are off the value is 0. If all relays are on it will be 255. Relay 1 is a value of 1 relay 2 would convert to 2 relay 3 would be 8 relay 4 would be 16 relay 5 would be 32, etc. the total of these numbers would be the result you see graphed. Hopefully Roberto can add the ability for us to display the relay data graph on the portal in the uapp
bboss
Re: Universal App
Are you planning to make this UAPP available in Windows Store? I know it can be accessed through web browsers, but it would be really cool if I could pin this app to the start menu, especially on a Windows Phone.
Re: Universal App
There are no plan for that. I don't even know how to create a windows phone app
randynixon74
Water Level on new app versio
I recently installed the latest version of uApp on iPhone and can't get the water level readout to move from 0. When I click into the 0 for the detail graph, it does show the correct current level. Is this a bug in the current version? It worked ok in the last version.
Randy Nixon
120g Acrylic Mixed Reef Tank
- GiraffeCat
Re: Universal App
I would love a native windows 10 app, as I cannot get the web version to run on IE or Edge properly. With the guide I found here: https://msdn.microsoft.com/en-us/window ... form-guide , it appears you can tailor it to fit whichever devices you want.rimai wrote:There are no plan for that. I don't even know how to create a windows phone app
I would even pay for it. (Who wants money?) A nice full featured Windows 10 app like the U-App is.
Maybe when I am done with my current degree I can take some programming classes, but that won't be for a few years. Coding is tough, from what I hear.
Later,
Dan
.....Your forefathers wisely set aside their compassion - Steeled themselves for what needed to be done.......
troylong45
troylong45
troylong45
Re: Universal App
Is there plans to add pwme selection in the graph option on the Web app all there is ,is just temp and PH selection and custom sucks putting in pmwe# everytime for all 6 channels plus the stock ones lol.
Re: Universal App
Make a bookmark in your web app http://forum.reefangel.com/status/chart ... lter=pwme1
paperdesk
Re: Universal App
Is the Android download link working for anyone? I just get "404 not found" error.
paperdesk
Re: Universal App
Robert got the link fixed and it's working again now!paperdesk wrote:Is the Android download link working for anyone? I just get "404 not found" error.
Ted
- cosmith71
Re: Universal App
The QR codes are borked.
Smotz
Re: Universal App
I understand the tunneling work around but I would really like it if the U-App could support the wifi authentication.
troylong45
Re: Universal App
Fixed.
You should be able to download now.
You can also use the web version of the Uapp:
http://forum.reefangel.com/uapp/
Smotz
Re: Universal App
You guys are awesome
troylong45
troylong45
Re: Universal App
if i use the browser how do i get on it from there and can i get it to do live feed vs updates every XXX mins
Re: Universal App
Live feeds is only possible with the cloud server.
The current wifi attachment cannot connect to the cloud server.
You will need the cloud wifi attachment that has not been released yet.
The cloud server implements MQTT protocol so live feeds get updated on the fly on Uapp through jquery and paho mosquitto library.
Re: Universal App
If you want to see it working, go to http://forum.reefangel.com/uapp/ and add a new controller with these settings:
Name: Anything you want
ip address: leave blank
port: leave blank
username: cloudtest2
password: 123456
I have this test controller online right now.
port: leave blank
password: 123456
GugsJr
Re: Universal App
I wasn't sure if I should add the request here or into it's own thread. Figured why add an extra thread.
For the Android App could you make it that when you get a flag (lets use ATO), and you go to the flag section it will clear if you tap it instead of going into the menu?
