The basic functions work for me minus having wavemaker switch on n off, and bought the additional led moonlight , and need to figure out how to set that up as well . any help would be greatly appreciated.// Autogenerated file by RAGen (v1.1.0.127), (01/31/2012 12:27)
// RA_013112_1227.pde
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.StandardFan(Port6);
demo code
woods4542000
demo code
Im trying just to change the demo code in ragen to have wavemakers on all time off at water change etc. saying port 4 not declared ?
Re: demo code
Make sure you convert/update your libraries to development libraries.
http://forum.reefangel.com/viewtopic.php?f=8&t=2
To use the moonlight, just add this line to your loop():
woods4542000
Re: demo code
wow thanks a lot , now I can hook this up to my system!!!
woods4542000
Re: demo code
Everything went well except not turning on metal halide socket?
woods4542000
Re: demo code
Not turning off sockets 4,5,8 during water change either?
woods4542000
Re: demo code
This is what i have.// Autogenerated file by RAGen (v1.1.0.127), (01/31/2012 15:04)
// RA_013112_1504.pde
#define VersionMenu
#define wifi
#define SIMPLE_MENU
Re: demo code
Which app are you using to change the light schedule?
For the feeding and water change mode, you need to add this inside the setup() function
ReefAngel.FeedingModePorts = B10011000;
ReefAngel.WaterChangePorts = B10011000;
woods4542000
Re: demo code
Wow Im so lost right now, tried changing light times in internal memory says error compiling. i did the initial memory save . tried getting reef angel client , cant get that to work. Ive been messing with this just under a week and its killing me.
