RA portal charts does not have new data
PostPosted: Mon Dec 26, 2016 8:27 pm
It appears that on my portal, the data for the relay graphs end at 4pm on DEC 23rd. Same goes for Temp and PH. Is there something that I have done to make it stop?
Here is my code:
//#include <Salinity.h>
//#include <RF.h>
//#include <ORP.h>
//#include <WaterLevel.h>
//#include <Humidity.h>
//#include <PAR.h>
#define Mem_B_MoonOffset      100
#define Mem_B_Vacation        101
#define Mem_B_AutoFeed        102
#define Mem_B_AutoFeedPress   103
#define Mem_B_AutoFeedRepeat  104
#define Mem_B_AutoFeedOffset  105
#define Mem_I_WCFillTime      106
byte wc_status = 0;
time_t ato_endfill;
byte ato_topping = 0;
void init_memory() {
  InternalMemory.write(Mem_B_Vacation,false);
  InternalMemory.write(Mem_B_AutoFeed,true);
  InternalMemory.write(Mem_B_AutoFeedPress,2);
  InternalMemory.write(Mem_B_AutoFeedRepeat,4);
  InternalMemory.write(Mem_B_AutoFeedOffset,3);
  InternalMemory.write_int(Mem_I_WCFillTime,1200  );  //How long topoff is allowed to run
  // Define Relay Ports by Name
#define Daylight           1
#define LEDLights          2
#define ATODrain           3
#define Feeder             4
#define Mixer              5
#define Topoff             6
#define Ferts              7
#define Filter             8
  ReefAngel.Relay.Auto(Filter);
    ato_endfill = now()+15;  //add delay to ato startup
  // Ports that default off
  ReefAngel.Relay.Off(Topoff);
  ReefAngel.Relay.Off(ATODrain);
  ReefAngel.Relay.Off(Feeder);
  ReefAngel.Relay.Off(Mixer);
ReefAngel.CustomLabels[0]="Daylight";
ReefAngel.CustomLabels[1]="LED";
ReefAngel.CustomLabels[2]="Drain";
ReefAngel.CustomLabels[3]="Feeder";
ReefAngel.CustomLabels[4]="Mixer";
ReefAngel.CustomLabels[5]="Topoff";
ReefAngel.CustomLabels[6]="Ferts";
ReefAngel.CustomLabels[7]="Filter";
ReefAngel.Relay.On(Filter);
    ReefAngel.StandardLights( LEDLights,9,0,21,0 );
    ReefAngel.StandardLights( Daylight,10,30,20,30 );
    ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,15,100,60,15) );
    //Automation
    //RunFeeder();
      //RUN ONCE A DAY AT 7 AM FOR 40 MIN
      ReefAngel.DosingPumpRepeat(ATODrain,660,1440,2400 );
    //Water Change
      if (ReefAngel.Relay.Status(ATODrain) ){
        wc_status = 1;
      if (wc_status > 0 ){
        AutoWaterChange();
    //Keep Water topped off
    AutoTopOff();
    ReefAngel.Portal( "diverjoe" );
    ReefAngel.DDNS("75");
void AutoTopOff(){
 //run for 15 sec any time float valve is turned on and WC drain is not active
 if (ato_endfill < now() && wc_status != 1 && ato_topping){
     ReefAngel.Relay.On(Topoff);
 else{
   ato_topping = 0;
   if ( ReefAngel.HighATO.IsActive() && !ato_topping){
       ato_endfill = now() + 15;
       ato_topping = 1;
void RunFeeder() {
  boolean autoFeed;
  static time_t t;
  int press, repeat, offset;
  autoFeed=InternalMemory.read(Mem_B_AutoFeed);
  press=InternalMemory.read(Mem_B_AutoFeedPress);
  repeat=InternalMemory.read(Mem_B_AutoFeedRepeat)*SECS_PER_HOUR;
  offset=InternalMemory.read(Mem_B_AutoFeedOffset)*SECS_PER_HOUR;
  ReefAngel.Relay.Set(Feeder, autoFeed);
  if (ReefAngel.Relay.Status(Feeder)!=autoFeed) {
    autoFeed=ReefAngel.Relay.Status(Feeder);
    InternalMemory.write(Mem_B_AutoFeed, autoFeed);
    ReefAngel.Relay.Auto(Feeder);
  if (autoFeed) {
    if (((hour() > 9 && hour() < 20)) && (now()+offset)%repeat==0) {
      t=now();
  if (ReefAngel.Relay.isMaskOn(Feeder)) {
    t=now()-now()%20; // One feeding has already happened.
  // Press the button once every 20 seconds
  if (now()-t < press*20) {
    ReefAngel.Relay.Set(Feeder,now()%20==0);
  } else {
void AutoWaterChange() {
 int NowMins;
 static time_t t;
    if (wc_status == 1) {
      ReefAngel.Relay.Override(Topoff,0);
      //ReefAngel.Relay.Override(Filter,0);
      ReefAngel.Relay.Off(Filter);
      t = now();
    if(ReefAngel.LowATO.IsActive() && wc_status == 1)
      wc_status = 2;   //Enter Mix mode
      ReefAngel.Relay.Auto(ATODrain);
      ReefAngel.Relay.On(Mixer);
      ReefAngel.Relay.Auto(Topoff);
      //ReefAngel.Relay.On(Topoff);
      t = now();
    //Ferts Mode
    if ( wc_status == 2){
      if (now() - t > SECS_PER_MIN  * 6){
           wc_status = 3;   //enter Ferts mode
           ReefAngel.Relay.On(Ferts);
            t = now();
    //ferts Mode
     if ( wc_status == 3){
      if (now() - t > 15){
           ReefAngel.Relay.Off(Ferts);
           wc_status = 0;
// Disable masks for things that should not be turned on by mistake
void LockPorts() {
  ReefAngel.AddPortOverrides();
PostPosted: Tue Dec 27, 2016 5:57 am
I noticed the same, cant get current info.
thanks
PostPosted: Tue Dec 27, 2016 6:08 am
Yep same here. I have nothing from December 24th onwards. I thought it was something I did wrong and have been digging through all sorts of places to find the problem. I also use the 'Reef Angel Client' windows program, which also cannot get any data.
PostPosted: Tue Dec 27, 2016 6:09 am
My reefangelid:
silkjc
Connection Status:
Ready
Last Update:
12/28/2016, 12:09:05 AM
Displaying data from:
Reef Angel Controller (live)
Graphs have no data from December 24th onwards.
PostPosted: Tue Dec 27, 2016 11:24 am
Try updating the settings on the wifi attachment with this macro:
viewtopic.php?f=3&t=4601
PostPosted: Tue Dec 27, 2016 10:32 pm
I performed the wifi macro using Teraterm with the wifi device plugged in to a local COM. During this process I noticed my RA's clock had reset back to the year 00, so I updated that as well.
Seems to have come good and I now have a last update date of today on the portal. Web charts haven't updated yet though.
As an aside and it might be a chrome cache problem, but sometimes when I refresh the page the last updated date goes back to the last reading at 24/12/2016 momentarily before changing to 28/12/2016.
Edit: Checked this and it does it in IE as well (which I've never visited the portal on). So its got some weird fixation on that date! Charts have not updated yet
PostPosted: Wed Dec 28, 2016 2:00 am
Update: Web charts still have no new data since the 24th.
PostPosted: Wed Dec 28, 2016 3:01 am
Just loaded up the portal and it took 4 page refreshes until the 'Last update date' went from
Last Update:
12/24/2016, 8:16:25 AM
to:
Last Update:
12/28/2016, 9:00:32 PM
Very weird
PostPosted: Wed Dec 28, 2016 9:31 am
The first date is from the portal database and the last one is when the portal is able to contact live data from the controller.
When you load the portal, it will always use the first date until it is able to connect to gather live data.
Just to be sure it is not the wifi attachment, I'd like you to confirm the settings are saved in there.
Use Tera Term again and connect to your COM port using baud rate 57600.
Then, type $$$ within one second.
The wifi attachment will return with CMD response.
Then you type get e and you should get a response with all the settings.
Copy and paste here.
If you cannot get this to work, send me a PM and I can connect remotely.
PostPosted: Wed Dec 28, 2016 10:47 pm
I am having the same problem. Last data recorded in the webchart is Dec 23 3:15pm. I have tried rebooting the controller. Rebooting the WiFi adapter by unplugging and plugging. Updated the time and date on the controller, even though that seemed correct before updating.
I think that the problem has got to be in the server. Too much of a coincidence that four people have the same issue starting at virtually the same time and day. Right?
I am able to control my controller through the Portal (live).
Next
Return to For New Members
