Wifi or app issue?
nevets9333
Wifi or app issue?
I have the app on my iphone, and have had no issues for the past year. Now for some reason I cannot see an updated graph when I try to look at the PH/temp. If i refresh the home screen I get real time stats, but if I go to create a graph it won't update past the 20th of Dec. Any idea why I can see updated info but can't graph it? It seems my portal is also not updating past the 20th. Thanks, Steven.
Re: Wifi or app issue?
Try updating the settings on the wifi attachment with this macro:
nevets9333
Thank you. Not too familiar with this kind of stuff so I don't know if I am doing it correctly. When I open tera term, select the serial port, open the updated file with macro I get "start wifly module configuration" and click ok. When I open the wifi utility and hit connect I get "ERROR: Connecting to COM3 and Error inside serial.<init>()"
nevets9333
So after I click OK on the start wifly module configuration what do I do? All I see is a bunch of symbols and numbers appear across the screen.
nevets9333
You are not connecting with the correct baud rate. It needs to be 57600
nevets9333
Thank you so much! I truly appreciate your patience and help!
