Blank Screen RAStar
Ask in here.
Xender
Blank Screen RAStar
Post by Xender »
Hello,
I have a blank screen on my RAStar can you help me please ? :
I have
RANet relay box
Dimming Expansion
I tried to use Web Wizard and there is not yet RAStar white version? (propotype)
Thx for your help
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
    ReefAngel.Star();
    ReefAngel.AddStandardMenu();
    ReefAngel.AddRANet();  // RANet Add-On Module
    // Ports turned off when Leak is detected
    ReefAngel.LeakShutoffPorts = 0;
    InternalMemory.OverheatTemp_write( 300 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    //ReefAngel.LeakShutoffPorts = Box1_Port3;
    ReefAngel.StandardLights( Port1,8,0,23,0 );
    ReefAngel.StandardLights( Port2,8,0,23,0 );
    ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 0,PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 1,PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 2,PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 3,PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 4,PWMSlope( 9,0,23,0,15,70,60,0 ) );
    boolean buzzer=false;
    if ( ReefAngel.isOverheat() ) buzzer=true;
    //CO2
    // if ( ReefAngel.Params.PH <= 600 )
      //ReefAngel.Relay.Off(Box1_Port5);
     //if ( ReefAngel.Params.PH >= 700 )
      //ReefAngel.Relay.On(Box1_Port5);
    //Week days light ON/OFF
   InternalMemory.write(0, 17);
   InternalMemory.write(1, 00);
   InternalMemory.write(2, 00);
   InternalMemory.write(3, 00);
   InternalMemory.write(4, 17);
   InternalMemory.write(5, 00);
   InternalMemory.write(6, 00);
   InternalMemory.write(7, 00);
//   if ( (weekday() == 1) || (weekday() == 7) ) // Sunday or Saturday
//   // 0 - on hour, 1 - on minute, 2 - off hour, 3 - off minute
//   // 4 - on hour, 5 - on minute, 6 - off hour, 7 - off minute
//      ReefAngel.StandardLights(Box1_Port1, InternalMemory.read(0), InternalMemory.read(1), InternalMemory.read(2), InternalMemory.read(3));  // Weekend schedule
//      ReefAngel.StandardLights(Box1_Port2, InternalMemory.read(4), InternalMemory.read(5), InternalMemory.read(6), InternalMemory.read(7));  // Weekend schedule
//     } else
//      ReefAngel.StandardLights(Box1_Port1,17,0,23,0 );  // Weekday schedule  (use standard internal memory values)
//      ReefAngel.StandardLights(Box1_Port2,17,0,23,0 );  // Weekday schedule  (use standard internal memory values)
    ReefAngel.Network.Cloud();
// RA_STRING1=$$$$$$$$$
// RA_STRING2=null
// RA_STRING3=null
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
Click Here to see the Video of my Fresh Water Aquarium
Re: Blank Screen RAStar
I think you need to take out these two lines:
Oh, and the RANet line right after that, too.
Xender
Post by Xender »
Same :
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
int DaylightPWMValue=0;        // For cloud code
    ReefAngel.Star();
    //ReefAngel.AddStandardMenu();
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    //ReefAngel.AddRANet();  // RANet Add-On Module
    ReefAngel.Portal("Xender","$$$$$");
    //ReefAngel.Network.WifiAuthentication("Xender:$$$$$$");
    //Cloud
    DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,85,60,0);
    CheckCloud();
    ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
    //CO2
//     } else
void CheckCloud()
#define Clouds_Every_X_Days 1
  // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Mega2,Mega,Mega};
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=4095;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
    /*ReefAngel.LCD.Clear(255,0,120,132,132);
     ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
      int x=0;
      else x=17;
      //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
      else x=35;
      //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
    //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
      //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
// RA_STRING1=$$$$
// RA_STRING2=null
// RA_STRING3=null
By the way, what is for RA_STRING1 ???
Thx
Xender
Post by Xender »
For info :
Reef Angel Libraries Found: Development
Reef Angel Libraries Version: 1.1.3
I can't remember which one is the one you have.
Is it with the touch screen?
Xender
Post by Xender »
No touch screen.
Yeah.... I think only you and Lee have one of those early prototypes.
We changed the screen to a touch version and abandoned the small screen.
I don't think the screen will work for you anymore :(
But you can however use the cloud features still and just use a tablet for live data stream.
Xender
Post by Xender »
:( what the touch screen looks like?
No upgrade available?
How the cloud works?
The cloud will allow you to have live data stream without need of port forwarding and there is no refresh needed either.
Generate a code on the webwizard for RA Star and use the uapp to connect to the cloud server.
http://forum.reefangel.com/uapp/
When setting up the profile, don't enter any ip nor port and enter your forum username and password on the cloud server settings.
It should connect to the cloud server and start updating the parameters and relay status.
You will need to reset your forum password before doing anything though, because your forum username was created before we launched the cloud server.
Xender
Post by Xender »
Hello Rimai,
Uapp is not working for me :-( : http://forum.reefangel.com/uapp/
Cloud setting : xender and my forum password
I reseted my forum password as you ask
here is my code :
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
    //InternalMemory.LCDID_write(255);
    ReefAngel.Star();
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.FeedingModePorts = Box1_Port8;
    ReefAngel.WaterChangePorts = Box1_Port8;
    //ReefAngel.OverheatShutoffPorts = Box1_Port1 | Box1_Port2;
    ReefAngel.LeakShutoffPorts = Box1_Port1 | Box1_Port2;
    //ReefAngel.LightsOnPorts = Box1_Port1 | Box1_Port2;
    //ReefAngel.Relay.On( Box1_Port5 );
    //ReefAngel.Relay.On( Box1_Port8 );
    ReefAngel.Portal("Xender","xxxx");
    //ReefAngel.Network.WifiAuthentication("xxxx:xxxxx");
    //ReefAngel.StandardLights( Box1_Port1,8,0,23,0 );
    //ReefAngel.StandardLights( Box1_Port2,8,0,23,0 );
    //ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    //ReefAngel.PWM.SetActinic( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    //ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    //ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 0,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 1,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 2,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 3,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    ReefAngel.PWM.SetChannel( 4,PWMSlope( 8,0,23,0,15,70,60,0 ) );
    if ( ReefAngel.IsLeakDetected() )
        buzzer=true;
      } else
        buzzer=false;
        buzzer=true;
      } else
        buzzer=false;
    //CO2
    ReefAngel.CO2Control( Box1_Port5,720,710 );
      ReefAngel.StandardLights(Box1_Port1, 8,0,23,0 );  // Weekend schedule
      ReefAngel.StandardLights(Box1_Port2, 8,0,23,0 );  // Weekend schedule
     } else
      ReefAngel.StandardLights(Box1_Port1,8,0,23,0 );  // Weekday schedule  (use standard internal memory values)
      ReefAngel.StandardLights(Box1_Port2,8,0,23,0 );  // Weekday schedule  (use standard internal memory values)
// RA_STRING1=xxxx
// RA_STRING2=null
// RA_STRING3=null
Just to be sure, your code does have the RA_STRING1 in it and you just erased, right?
RA_STRING1 is the password that RA will use to connect to the cloud server.
If you reset it after you encrypted the password, you will have to generate the code again to encrypt the password again.
